楼主 |
发表于 2011-9-7 20:58:14
显示全部楼层
回复 13# jiancongwoo
thanks all.
and I check the hold violations, and found one strange things:
the clock network delay is always much bigger in Required path than in Arrival path. to put it simply:
(1), I set the network delay(network + source = 2ns) in SDC before CTS, but the value of the clock network delay(ideal) is ranged from 5 to 10(before CTS), and the value in RT is much bigger than AT, why?
(2), after CTS the propagated network delay(propagated): values in RT is also much bigger than AT, why ?
thanks in advance. |
