查看: 3944|回复: 1
[求助] 警告求助。。。。
发表于 2011-5-7 15:50:56 | 显示全部楼层 |阅读模式
WARNING:Xst:2677 - Node <ad_d_4> of sequential type is unconnected in block <DDS>.
WARNING:Xst:1895 - Due to other FF/Latch trimming, FF/Latch  <odata1_2> (without init value) has a constant value of 0 in block <V_measure>.
WARNING:Xst:2734 - Property "use_dsp48" is not applicable for this technology.
WARNING:Xst:2211 - "D:/example/scan/dds.vhd" line 58: Instantiating black box module <sin>.
发表于 2011-5-8 23:39:02 | 显示全部楼层
警告表明,DDS做了逻辑和端口优化。如果不影响功能,那么是无所谓的。
GMT+8, 2025-10-30 09:20 , Processed in 0.017395 second(s), 5 queries , Gzip On, Redis On.
