查看: 2876|回复: 2
[求助] Ecounter specifyLockupElement 命令的使用
发表于 2011-4-5 13:51:23 | 显示全部楼层 |阅读模式
请问各位大侠,specifyLockupElement 命令在什么情况下使用呢?
这个lockup element 指的是什么cell啊?用这个命令的目的又什么呢?
发表于 2011-4-6 10:25:12 | 显示全部楼层
看man:
lockup cell是 scanchain上 2个clock domain/phase 经过的cell,特殊单元吧,
NAME
SYNTAX
              {-cell <leafCellName> | -inst <instName>}
              -in <ftname>
              -out <ftname>
DESCRIPTION
       Specifies  a cell or instance as a lockup element. Lockup elements are present in scan chains where the chain crosses between two different clock domains or clock phases.
       Use this command after running placement.
       Parameters
                                                 Specifies the cell to be a lockup element.
           -in <ftname>                          Specifies the name of the scan input.
           -inst <instName>                      Specifies the instance to be a lockup element.
           -out <ftname>                         Specifies the name of the scan output.
       Example
 楼主| 发表于 2011-4-9 23:18:46 | 显示全部楼层
多谢楼上!
GMT+8, 2025-12-22 03:08 , Processed in 0.016004 second(s), 6 queries , Gzip On, Redis On.
