查看: 8324|回复: 1
[解决] 组播setsockopt:no such device问题的解决方法
发表于 2010-10-28 15:14:17 | 显示全部楼层 |阅读模式
What does "IP_ADD_MEMBERSHIP: No such device" mean?
It means that the tool is trying to use multicast but the network interface doesn't support it There are two likely causes:
·Your machine doesn't have multicast support enabled. For example, on Linux and FreeBSD it is possible to compile a kernel which doesn't support multicast.
·You don't have a route for multicast traffic. Some systems don't add this by default, and you need to run:
route add -net 224.0.0.0 netmask 224.0.0.0 eth0(or similar). If you wish to use RAT in unicast mode only, it is possible to add the multicast route on the loopback interface.
发表于 2011-1-19 01:08:30 | 显示全部楼层
此帖仅作者可见
GMT+8, 2025-12-22 03:08 , Processed in 0.016287 second(s), 6 queries , Gzip On, Redis On.
