查看: 12582|回复: 4
[求助] 求spectre rf仿真license问题的解决方法
发表于 2011-9-15 16:48:07 | 显示全部楼层 |阅读模式
由于我的spectre版本太低,导致spectre rf仿真出现license问题:
Command line:
/apps/Cadence/IC5141/tools.lnx86/spectre/bin/32bit/spectre -env
artist5.1.0 +escchars +log ../psf/spectre.out +inter=mpsc
+mpssession=spectre1_4942_2 -format sst2 -raw ../psf +lqtimeout
900 input.scs
spectre pid = 5271
Loading /apps/Cadence/IC5141/tools.lnx86/cmi/lib/4.0/libinfineon_sh.so ...
Loading /apps/Cadence/IC5141/tools.lnx86/cmi/lib/4.0/libnortel_sh.so ...
Loading /apps/Cadence/IC5141/tools.lnx86/cmi/lib/4.0/libphilips_sh.so ...
Loading /apps/Cadence/IC5141/tools.lnx86/cmi/lib/4.0/libsparam_sh.so ...
Loading /apps/Cadence/IC5141/tools.lnx86/cmi/lib/4.0/libstmodels_sh.so ...
spectre (ver. 5.10.41_USR4.081106 -- 11 Aug 2006).
Includes RSA BSAFE(R) Cryptographic or Security Protocol Software from RSA
Security, Inc.
Simulating `input.scs' on eda at 3:06:12 PM, Thur Sep 15, 2011.
Warning from spectre during initial setup.
NM0: `Moin' = 800 is unusually large.
Circuit inventory:
nodes 3
equations 9
bsim3v3 2
vsource 2
Entering remote command mode using MPSC service (spectre, ipi, v0.0,
spectre1_4942_2, ).
Notice from spectre.
Waiting for available license for the Virtuoso(R) Spectre(R)-RF option.
是不是需要安装mmsim61?各位有什么其他好的建议吗?现在的系统是redhat AS4,安装的ic5141,需要卸载以前的低版本吗?
发表于 2011-9-19 23:44:57 | 显示全部楼层
不需要卸载以前版本,但是要把新toll 写在search path的前部分。
发表于 2012-5-14 17:57:19 | 显示全部楼层
这个警告是什么意思
发表于 2017-10-24 11:15:58 | 显示全部楼层
你好,你的问题解决了吗,现在我报了一个类似的warning一直解决不了
发表于 2022-12-23 09:35:13 | 显示全部楼层
这个警告是什么意思
你好,同问这个是什么意思
GMT+8, 2025-12-12 04:16 , Processed in 0.018350 second(s), 5 queries , Gzip On, Redis On.
