查看: 3755|回复: 3
Gain-Bandwidth product=constant
发表于 2009-11-24 12:29:47 | 显示全部楼层 |阅读模式
在回授系統中,為何說 Gain-Bandwidth product=constant ??
有高手願意解答ㄇ
发表于 2009-11-24 13:08:20 | 显示全部楼层
这是single pole时的情况
let an amplifer: A(s)= A/(1+s/p1)
the feedback factor is : beta
then the close loop gain of the feedback system is : A(s)/[1+ A(s)*beta]=A/(1+s/p1+A*beta)
  =>s=-(1+A*beta)p1 , that is the dominate pole of the feedback system, p_fb=(1+A*beta)p1
if A*beta >> 1, then p_fb=A*beta*p1, => p_fb*(1/beta)=A*p1
here:
1/beta is the close loop dc gain of the feedback system, so any (single pole ) feedback system, the gain * the bandwith is a constant which equals to the dc open loop gain of the amplifier * the bandwidth of the amplifier, the gain bandwidth of the amplifier with any feedback factor is not changed!
hope helpful
发表于 2009-11-25 20:31:50 | 显示全部楼层
miller compensation makes p1>>p2,
so in such 2 stage op, you can consider it as a simple pole system
then above formula is right
发表于 2009-11-27 21:27:13 | 显示全部楼层
仅仅是单极点近似才成立
GMT+8, 2025-12-29 16:13 , Processed in 0.023579 second(s), 7 queries , Gzip On, Redis On.
