查看: 18394|回复: 53
candence入门教材
发表于 2008-3-4 19:58:26 | 显示全部楼层 |阅读模式
包括两个文件。
目录如下:
其一:
CONTENTS
1. INTRODUCTION
2. ANALOG IC DESIGN FLOW AND REQUIRED TOOLS
3. SETTING YOUR UNIX ENVIRONMENT
4. RUNNING CADENCE
5. ANALOG DESIGN WITH CADENCE DESIGN FRAMEWORK II
5.1. Library Creation and Selection of Technology
5.2. Schematic Entry with Composer
5.2.1. Symbol Creation
5.3. Simulation
5.3.1. Setting simulator
5.3.2. Setting models
5.3.3. Setting design variables
5.3.4. Selecting the analysis
5.3.5. Running the simulation
5.3.6. Plotting the simulation results
5.4. Layout
5.4.1. Basic Full-Custom Layout
5.4.2. Full custom layout using pcells
5.4.3. Fill-custom layout using Virtuoso XL
5.4.4. Hierarchical layout
5.5. Verification
5.5.1. Design Rule Check (DRC)
5.5.2. Layout versus Schematic (LVS)
6. TRANSFER TO FOUNDRY
7. PRINTING IN CADENCE
8. REFERENCES
APPENDIX: ADVANCED TOPICS
A.1. TRANSITION GUIDE FROM TANNER TOOLS TO CADENCE
A.2. INTRODUCTION TO SKILL
A.3. LOGIC SIMULATION WITH VERILOG
其二:
Contents
1 Introduction
2 Virtuoso Layout Editing
2.1 Setting Up the Environment
2.2 Layer Selection Window (LSW)
2.3 Creating Shapes and Objects
2.4 Selecting Objects for Edit
2.4.1 Selection modes
2.4.2 Selecting objects
2.5 Editing Objects
2.5.1 Moving Objects
2.5.2 Copying Objects
2.5.3 Deleting Objects
2.5.4 Stretching Objects
2.5.5 Merging Objects
2.6 Saving the Design
3 Inverter Layout : Design rule & Mask layers
3.1 Design Rules
3.2 Mask Layers
3.2.1 Diffusion areas for source, drain, and substrate contacts
3.2.2 N-well regions
3.2.3 Contacts
3.2.4 Metal power ground and signal routing layers
4 Layout Verification
4.1 Design Rule Check (DRC)
4.2 Connectivity Extraction
4.3 Layout Versus Schematic (LVS) Software
4.3.1 Running LVS
4.3.2 Displaying the Errors
4.3.3 Probing the Schematic and Layout
5 Layout Simulation
6 Hierarchal Layout Editing
cadence.rar
1.92 MB, 下载次数: 471 , 下载积分: 资产 -2 信元, 下载支出 2 信元
发表于 2008-3-5 16:37:18 | 显示全部楼层
謝謝大大分享~
发表于 2008-3-5 16:43:18 | 显示全部楼层
可惜没有钱啊
发表于 2008-3-5 21:13:19 | 显示全部楼层
need money too
发表于 2008-11-2 22:10:38 | 显示全部楼层
thankyou
谢谢了...
发表于 2008-12-23 21:07:41 | 显示全部楼层
谢谢了
谢谢了谢谢了
发表于 2008-12-27 13:01:25 | 显示全部楼层
谢谢了谢谢了
发表于 2009-2-8 06:37:35 | 显示全部楼层
Thanks for sharing
发表于 2009-8-7 09:37:28 | 显示全部楼层
下来看看是什么东西,下载了!
发表于 2009-8-7 09:46:39 | 显示全部楼层
适合初学者,顶。
GMT+8, 2025-12-15 13:18 , Processed in 0.028240 second(s), 7 queries , Gzip On, Redis On.
