楼主: pps453
618没有cdb2oa选项怎么办?
发表于 2024-5-11 09:39:20 | 显示全部楼层
官网上明确写了The cdb2oa translator that converts CDB database (IC5.1.41) to OA or OpenAccess has been removed in IC6.1.8/ICADVM18.1 ISR13
The last release using CDB was IC5141, which was released in 2004, and had its final hotfix in 2011. cdb2oa has continued to be supported for many releases beyond the end of release of IC5141. However, continuing to support the old CDB code needed to enable the translator does not make sense when the vast majority of data has already been translated.
If you need to migrate any CDB data to OpenAccess, you can either use an IC/ICADVM ISR prior to the removal (e.g. ISR12), or use the Base release of IC6.1.8/ICADVM18.1 which are available on downloads.cadence.com . It is anticipated that these releases will remain available on downloads.cadence.com for some time, but you should ensure that you have a release downloaded and available to cater for any future translations you might need.
Note: For CDB to OpenAccess migration refer ‘CDB to OpenAccess Translator User Guide’. The guide is available as part of the IC hierarchy ( release IC618_ISR12 or below). The pdf of the guide is located at  <IC_Install_Path>/doc/cdboa/cdboa.pdf .
GMT+8, 2025-12-30 16:11 , Processed in 0.014599 second(s), 5 queries , Gzip On, Redis On.
