查看: 5717|回复: 30
ESD Protection Design for Mixed-Voltage I/O(Ker)
发表于 2008-1-18 22:20:09 | 显示全部楼层 |阅读模式
ESD Protection Design by Using Only 1×VDD
Low-Voltage Devices for Mixed-Voltage I/O
Buffers with 3×VDD Input Tolerance
Ming-Dou Ker and Chang-Tzu Wang
Institute of Electronics, National Chiao-Tung University
1001 Ta Hsueh Road, Hsinchu, Taiwan, E-mail: mdker@ieee.org
Abstract
A new electrostatic discharge (ESD) protection design
by using only 1×VDD low-voltage devices for mixed-voltage I/O
buffer with 3×VDD input tolerance is proposed. A special ESD
detection circuit has been proposed to improve ESD protection
efficiency of ESD clamp device by substrate-triggered technique
to achieve high ESD level. This design has been successfully
verified in a 0.13-μm CMOS process to provide an excellent
circuit solution for on-chip ESD protection in the mixed-voltage
I/O buffers with 3×VDD input tolerance.
ASSCC_2006_Ker_CTWang.pdf
1.72 MB, 下载次数: 355 , 下载积分: 资产 -2 信元, 下载支出 2 信元
 楼主| 发表于 2008-1-18 22:21:45 | 显示全部楼层
CONCLUSION
A novel circuit solution on ESD protection design realized
with 1×VDD devices for mixed-voltage I/O buffer with
3×VDD input tolerance and single VDD supply has been
successfully verified in a 0.13-μm CMOS process. The
four-mode (PS, NS, PD, and ND) ESD stresses and pin-to-pin
ESD stresses on the 1.2/3.3-V mixed-voltage I/O buffer can be
effectively discharged by the proposed ESD protection scheme
without gate-oxide reliability issue. The turn-on behavior of the
ESD clamp device has been measured to verify the
effectiveness of the ESD detection circuit. The experimental
results have confirmed that the ESD robustness of the 3×VDD
mixed-voltage I/O buffer can be significantly increased up to
8kV with the proposed ESD protection scheme.
 楼主| 发表于 2008-1-18 22:22:48 | 显示全部楼层
REFERENCES
[1] C.-H. Chuang and M.-D. Ker, “Design on mixed-voltage I/O buffer with
blocking NMOS and dynamic gate-controlled circuit for
high-voltage-tolerant applications,” in Proc. IEEE Int. Symp. Circuits and
Systems, 2004, pp. 577–580.
[2] Y. Luo, D. Nayak, D. Gitlin, M.-Y. Hao, C.-H. Kao, and C.-H. Wang,
“Oxide reliability of drain engineered I/O NMOS from hot carrier
injection,” IEEE Electron Device Lett., vol. 24, no. 11, pp. 686–688, Nov.
2003.
[3] B. Serneels, T. Piessens, M. Steyaert, and W. Dehaene, “A high-voltage
output driver in a standard 2.5V 0.25μm CMOS technology,” in IEEE Int.
Solid-State Circuit Conf. Dig. Tech. Papers, 2004, pp. 146–147.
[4] W. R. Anderson and D. B. Krakauer, “ESD protection for mixed-voltage
I/O using NMOS transistors stacked in a cascode configuration,” in Proc.
EOS/ESD Symp., 1998, pp. 54–62.
[5] J. Miller, M. Khazhinsky, and J. Weldon, “Engineering the cascoded
NMOS output buffer for maximum Vt1,” in Proc. EOS/ESD Symp., 2000,
pp. 308–317.
[6] M.-D. Ker and S.-L. Chen, “Mixed-voltage I/O buffer with dynamic
gate-bias circuit to achieve 3×VDD input tolerance by using 1×VDD
devices and single VDD supply,” in IEEE Int. Solid-State Circuist Conf.
Dig. Tech. Papers, 2005, pp. 524–525.
[7] M.-D. Ker, W.-J. Chang, C.-T. Wang, and W.-Y. Chen, “ESD protection
for mixed-voltage I/O in low-voltage thin-oxide CMOS,” in IEEE Int.
Solid-State Circuits Conf. Dig. Tech. Papers, 2006, pp. 546–547.
[8] L. R. Avery, “ESD protection for overvoltage friendly input/output
circuits,” U.S. Patent 5708550, Jan. 1998.
[9] M.-D. Ker and K.-C. Hsu, “Latchup-free ESD protection design with
complementary substrate-triggered SCR devices,” IEEE J. Solid-State
Circuits, vol. 38, no. 8, pp. 1380–1392, Aug. 2003.
[10] M.-D. Ker and C.-H. Chuang, “Stacked-NMOS triggered siliconcontrolled
rectifier for ESD protection in high/low-voltage-tolerant I/O
interface,” IEEE Electron Device Lett., vol. 23, no. 6, pp. 363–365, June
2002.
发表于 2008-1-23 18:15:09 | 显示全部楼层
学习以下
发表于 2008-1-27 13:21:21 | 显示全部楼层
thanks
发表于 2008-2-17 22:40:21 | 显示全部楼层
hao
hao
hao
hao
发表于 2008-2-18 18:40:17 | 显示全部楼层
hao dongxi
发表于 2008-2-18 20:38:01 | 显示全部楼层
thakks
发表于 2008-2-27 16:26:12 | 显示全部楼层
极好.
发表于 2008-3-22 10:11:52 | 显示全部楼层
thanks
GMT+8, 2025-12-18 10:03 , Processed in 0.033416 second(s), 6 queries , Gzip On, Redis On.
