查看: 5845|回复: 15
[求助] 2.5D/3D先进封装设计/仿真方法?
发表于 2023-3-7 16:21:47 | 显示全部楼层 |阅读模式
请教各位大佬们:
   2.5D/3D先进封装设计和仿真与我们普通的SIP封装设计/仿真软件、设计/仿真流程有啥区别吗?井底之蛙,没见过猪跑,欢迎不吝赐教。
发表于 2023-3-20 01:44:56 | 显示全部楼层
2.5D / 3D are packaging methodology for including multiple IC inside the same package. In 2.5D structure, two or more active semiconductor chips are placed side-by-side on a silicon interposer for achieving extremely high die-to-die interconnect density. In 3D structure, active chips are integrated by die stacking for shortest interconnect and smallest package footprint.
In recent years, 2.5D & 3D has gained momentum as an ideal chiplet integration* platform due to their merits on achieving extremely high packaging density and high energy efficiency.
ASE is one of the pioneers in 2.5D/3D packaging technology and has successfully launched world’s first mass production of 2.5D IC package equipped with High Bandwidth Memory (HBM).
Benefits of 2.5D & 3D IC Packaging
Our 2.5D/3D IC packaging solution provides the benefit of integrating GPU, CPU and memory along with decoupling capacitor. Si interposer with TSV (Through Silicon Via) can be used as a platform to bridge fine pitch capability gap between assembly substrate and integrated circuit board. It also helps to keep pad pitch scaling path without being limited by assembly substrate technology.
Key advantages of applying 2.5D & 3D IC Packaging:
Ultra high routing density (L/S: 0.4/0.4µm)
Ultra high I/O density (> 400 µbumps/mm²) & I/O pitch scalability
Homogeneous / heterogeneous memory, power and/or optics integration
Interposer capable of embedding decoupling capacitor or active devices feasible
Excellent package reliability to meet automotive requirements
 楼主| 发表于 2023-3-21 17:07:10 | 显示全部楼层
各位老板,俺想了解的是:
2.5D/3D先进封装 设计和仿真 与我们普通的SIP封装设计/仿真软件、设计/仿真流程有啥区别吗?
 楼主| 发表于 2023-3-22 09:13:47 | 显示全部楼层
这个版块好冷啊,呼叫版主,请回答。。。。。。。。。
发表于 2023-4-9 17:06:25 | 显示全部楼层
好巧,我最近在愁2.5D怎么进行设计;可以家加个微信聊一下啊 PPQWMBZJM
发表于 2023-11-23 14:27:43 | 显示全部楼层
2.5D规模比较小的可以用APD撑一撑,规模大几十万bump的得用后端设计工具了。
发表于 2023-12-11 14:40:12 | 显示全部楼层
cobaltmoly, 为啥规模大了就得用后端设计工具了?是APD不支持吗?
发表于 2024-2-28 09:38:59 | 显示全部楼层
线宽线距小,APD太卡了,做不下去。
还有会用到一些后端工具的自动布线。
发表于 2024-5-23 10:58:31 | 显示全部楼层
cobaltmoly 发表于 2024-2-28 09:38
线宽线距小,APD太卡了,做不下去。
还有会用到一些后端工具的自动布线。
高端工具指的是有哪些呢?
发表于 2024-5-23 16:31:00 | 显示全部楼层
BBS_MaFu 发表于 2024-5-23 10:58
高端工具指的是有哪些呢?
后端工具,比如innovus和icc2
GMT+8, 2025-9-14 05:24 , Processed in 0.016814 second(s), 4 queries , Gzip On, Redis On.
