查看: 13690|回复: 14
请问always@(*)是什么意思,任何事件触发?
发表于 2007-12-4 10:50:37 | 显示全部楼层 |阅读模式
我最近看到一个代码是这样写的
always @ (*)
{状态机}
请问这个是所有事件都能触发么,这样写是不是不够好呢
发表于 2007-12-4 20:43:26 | 显示全部楼层
Verilog 标准2001中开始可以这样表示的,你可以去看看标准
9.7.5 Implicit event_expression list The event_expression list of an event control is a common source of bugs in RTL simulations. Users tend to forget to add some of the nets or variables read in the timing control statement. This is often found when comparing RTL and gate level versions of a design. The implicit event_expression, @*, is a convenient shorthand that eliminates these problems by adding all nets and variables which are read by the statement (which can be a statement group) of a procedural_timing_control_statement to the event_expression.
All net and variable identifiers which appear in the statement will be automatically added to the event expression with these exceptions: Identifiers which only appear in wait or event expressions.
Identifiers which only appear as a hierarchical_reg_identifier in the reg_lvalue of the left hand side of assignments.
Nets and variables which appear on the right hand side of assignments, in function and task calls, or case and conditional expressions shall all be included by these rules.
Examples:
Example 1 always @(*) // equivalent to @(a or b or c or d or f) y = (a & b) | (c & d) | myfunction(f);
Example 2 always @* begin // equivalent to @(a or b or c or d or tmp1 or tmp2) tmp1 = a & b; tmp2 = c & d; y = tmp1 | tmp2; end
Example 3 always @* begin // equivalent to @(b) @(i) kid = b; // i is not added to @* end
Example 4 always @* begin // equivalent to @(a or b or c or d) x = a ^ b; @* // equivalent to @(c or d) x = c ^ d; end
发表于 2007-12-5 20:17:42 | 显示全部楼层
ise中不是完全支持
发表于 2007-12-6 17:48:36 | 显示全部楼层
always @(*)
* 信號若是有變化,則會執行 always 區塊裡面的敘述。
一般來說,通常就是會合成組合邏輯 (Combinational Logic).
台灣式中文,希望你看得懂。
发表于 2007-12-9 15:34:04 | 显示全部楼层
z什么啊
发表于 2007-12-10 16:00:06 | 显示全部楼层
all the signals can trigged this process
发表于 2007-12-11 22:16:20 | 显示全部楼层
Verilog2001的新用法
发表于 2007-12-12 21:47:27 | 显示全部楼层
always模块中的所有赋值信号发生变化,都会触发模块重新计算.
电平敏感的纯组合逻辑.
发表于 2007-12-13 09:37:35 | 显示全部楼层
有些工具是不支持的,还是老老实实的写全敏感列表吧。
发表于 2007-12-13 11:23:29 | 显示全部楼层
好东西,顶啊
GMT+8, 2025-12-4 13:00 , Processed in 0.020985 second(s), 7 queries , Gzip On, Redis On.
