楼主: vectorli
[求助] 关于Techgen转QRC文件的流程
发表于 2023-11-1 16:55:58 | 显示全部楼层
学习一下
发表于 2023-12-4 06:41:14 | 显示全部楼层
上面的warnning 解决了 但是还是报ERROR 这个是咋回事呢
发表于 2024-4-24 10:05:53 | 显示全部楼层
老哥你解决这个问题了吗?我也遇到了一样的问题,可以说一下该怎么解决吗?
发表于 2024-5-24 13:57:01 | 显示全部楼层
axxqql 发表于 2019-12-27 11:16
这个东西转的就是很慢的。晚上丢下去。 -multi_cpu 不怕被骂你就写8啊,16啊。。。
请问 怎么调呢?直接改ict的内容吗、还是改脚本?
发表于 2024-6-19 22:50:22 | 显示全部楼层
我来解答吧,很简单,就是高度累加误差导致的.
我也折腾了好久,终于解决了!!!!
要手动改:看懂下面我例子就ok了.
40.01 itf to icl
./itf_to_ict.pl  ./StarRC_40LL_1P9M_2TM_CMAX.itf   ./StarRC_40LL_1P9M_2TM_CMAX.ict
40.02 icl to qrc
Techgen  -simulation -multi_cpu 8  ./StarRC_40LL_1P9M_2TM_CMAX.ict
如果报ERROR (EXTZTECH-213) : Error [input]: Layers ppoly and npoly in ICT file overlap.
都是高度累加value有问题,一定能要手动修改height值:
如果是poly要定义subconductor (因为不能设置厚度为0或者小于0的值,只有sub_conductor才有相同的height)
正确为:
conductor poly {
   min_spacing           5.7600E-02
   min_contact_poly_spacing   0.036
   min_width             3.6000E-02
   height                3.5000E-01
   thickness             7.7000E-02
   resistivity           1.6000E+01
   temp_tc1              1.6600E-03
   temp_tc2              -2.9500E-07
   gate_forming_layer    true
   layer_type gate
sub_conductor npoly {
   height                3.5000E-01
   temp_tc1              1.6600E-03
   wire_edge_enlargement_c {
     wee_widths  3.6000E-02
     wee_spacings 5.7600E-02
     wee_adjustments    0.0025
   wire_edge_enlargement_r {
     wee_adjustments    -0.0
sub_conductor ppoly {
   height                3.5000E-01
   resistivity           1.2820E+01
   temp_tc1              1.9200E-03
   temp_tc2              -3.4000E-07
     wee_adjustments    0.00376
错误为:
#conductor ppoly {
#   min_spacing           5.7600E-02
#   min_width             3.6000E-02
#   height                0.352565
#   thickness             7.7000E-02
#   resistivity
#   temp_tc1              1.9200E-03
#   temp_tc2              -3.4000E-07
#   gate_forming_layer           true
#   wire_edge_enlargement_c {
#     wee_widths  3.6000E-02
#     wee_spacings 5.7600E-02
#     wee_adjustments          0.0025
#conductor npoly {
#   height                0.352565
#   resistivity           1.6000E+01
#   temp_tc1              1.6600E-03
#   temp_tc2              -2.9500E-07
#   gate_forming_layer           false
另外也有报
ERROR (EXTZTECH-206) :   Error [input]: Layers ILD1a and ILD1b1 are not touching.
因为下面:
dielectric   ILD1a {
   conformal                    TRUE
   expandedFrom            poly
   height                       0.3525
   thickness                    0.0380  ( -> changed to 0.0381 to pass check!!!)
   topThickness            0.0380
   sideExpand                    0.0304
   dielectric_constant            7.000
dielectric   ILD1b1 {
   conformal                    FALSE
   height                       0.3906 != 0.3525+0.0380=0.3905
   thickness                    0.1420
   dielectric_constant            4.200
如上将高度height改成一样就可以,通常是改thickness,例如将ILD1a 的thickness                    0.0380-> changed to 0.0381
都是因为厚度thickness精度误差导致的。
发表于 2024-6-19 22:51:20 | 显示全部楼层
我也折腾了好久,终于解决了!!!!
要手动改:看懂下面我例子就ok了.
40.01 itf to icl
40.02 icl to qrc
正确为:
conductor poly {
   height                3.5000E-01
   temp_tc1              1.6600E-03
   layer_type gate
   height                3.5000E-01
   temp_tc1              1.6600E-03
   height                3.5000E-01
   temp_tc1              1.9200E-03
错误为:
#conductor ppoly {
#   height                0.352565
#   resistivity
#conductor npoly {
#   height                0.352565
另外也有报
因为下面:
dielectric   ILD1a {
   conformal                    TRUE
   expandedFrom            poly
   height                       0.3525
   topThickness            0.0380
   sideExpand                    0.0304
dielectric   ILD1b1 {
   conformal                    FALSE
   thickness                    0.1420
点评
谢谢!  发表于 2024-8-27 19:41
发表于 2024-7-2 14:38:34 | 显示全部楼层
学习 学习
发表于 2025-4-30 17:32:19 | 显示全部楼层
再次学习
GMT+8, 2025-12-18 18:59 , Processed in 0.020882 second(s), 5 queries , Gzip On, Redis On.
