查看: 10888|回复: 48
柯明道-ESD failure of analog IO cells in 0.18um CMOS
发表于 2007-9-6 17:22:55 | 显示全部楼层 |阅读模式
論文名稱ESD failure mechanisms of analog I/O cells in a 0.18-um CMOS technology
期刊Ming-Dou Ker, S.-H. Chen, and C.-H. Chuang “ESD failure mechanisms of analog I/O cells in a 0.18-um CMOS technology,” IEEE Trans. on Device and Materials Reliability, vol. 6, no. 1, pp. 102-111, Mar. 2006.
摘要        Different electrostatic discharge (ESD) protection schemes have been investigated to find the optimal ESD protection design for an analog input/output (I/O) buffer in 0.18-um 1.8- and 3.3-V CMOS technology. Three power-rail ESD clamp devices were used in power-rail ESD clamp circuits to compare the protection efficiency in analog I/O applications, namely: 1) gate-driven NMOS; 2) substrate-triggered field-oxide device, and 3) substrate-triggered NMOS with dummy gate. From the experimental results, the pure-diode ESD protection devices and the power-rail ESD clamp circuit with gate-driven NMOS are the suitable designs for the analog I/O buffer in the 0.18-um CMOS process. Each ESD failure mechanism was inspected by scanning electron microscopy photograph in all the analog I/O pins. An unexpected failure mechanism was found in the analog I/O pins with pure-diode ESD protection design under ND-mode ESD stress. The parasitic n-p-n bipolar transistor between the ESD clamp device and the guard ring structure was trggered to discharge the ESD current and cause damage under ND-mode ESD stress.
關鍵字Analog I/O, electrostatic discharge (ESD), failure
mechanism, input/output (I/O) cell, power-rail ESD clamp device
478_SHChen_TDMR_Mar_2006.pdf
1.35 MB, 下载次数: 459 , 下载积分: 资产 -2 信元, 下载支出 2 信元
发表于 2007-10-3 18:00:50 | 显示全部楼层
很棒的論文
謝謝分享
发表于 2007-10-24 22:14:53 | 显示全部楼层
Thanks
 楼主| 发表于 2008-7-30 18:28:54 | 显示全部楼层
发表于 2008-9-29 11:26:17 | 显示全部楼层
很棒的論文
发表于 2008-9-29 11:27:33 | 显示全部楼层
取消下载一次也扣钱
发表于 2008-11-13 15:55:51 | 显示全部楼层
henbucuo,xiexie
发表于 2008-11-20 13:56:11 | 显示全部楼层
thank you very much.
发表于 2009-1-4 15:21:56 | 显示全部楼层
eetopeetopeetopeetopeetopeetopeetopeetopeetopeetopeetopeetopeetop
发表于 2009-6-9 23:16:03 | 显示全部楼层
学习中,谢谢
GMT+8, 2025-12-29 16:49 , Processed in 0.032515 second(s), 9 queries , Gzip On, Redis On.
