查看: 2613|回复: 0
[招聘] 招聘验证工程师
发表于 2015-6-2 13:53:58 | 显示全部楼层 |阅读模式
Common:
1)
Familiar with system Verilog and UVM methodology
2)
Familiar with UNIX/Linux shell
3)
Familiar with Perl script
4)
Provide test plan basing on the design spec
5)
Setup the module level and chip level DV environment
6)
RTL simulation and netlist with timing simulation
7)
Implement the test cases basing test plan, and provide the test coverage
8)
Work with design team to repeat the failure case and find out root cause
Position 1:
1)
Familiar with the PCIe and NVMe protocol
2)
Familiar with SATA protocol
3)
Familiar with the NAND behavior and ONFI protocol
4)
Knowledge on ARM9 CPU core and AHB bus
5)
Knowledge on DDR3/LPDDR2
6)
Knowledge on AES and BCH ECC will be a plus
Position 2:
1)
Familiar with eMMC protocol
2)
3)
Knowledge on BCH ECC
Postion 3:
1)    Familar with mixed signal design and/or verification
Postion 4:
1)  Familar with one of the areas below:
     a. ARM A9 subsystem
     b. DDR3/DDR4
     c. USB 3.0
     d. SATA
     e. PCIe
     f. Ethernet
(在上海或者北京工作)send resume to cissy_pq@163.com if you are interested.
GMT+8, 2025-12-24 23:14 , Processed in 0.113791 second(s), 4 queries , Gzip On, Redis On.
