查看: 2077|回复: 0
[招聘] 招聘验证工程师
发表于 2015-5-13 09:55:56 | 显示全部楼层 |阅读模式
JD:Common:
1)
Familiar with system Verilog and UVM methodology
2)
Familiar with UNIX/Linux shell
3)
Familiar with Perl script
4)
Provide test plan basing on the design spec
5)
Setup the module level and chip level DV environment
6)
RTL simulation and netlist with timing simulation
7)
Implement the test cases basing test plan, and provide the test coverage
8)
Work with design team to repeat the failure case and find out root cause
Position 1:
1)
Familiar with the PCIe and NVMe protocol
2)
Familiar with SATA protocol
3)
Familiar with the NAND behavior and ONFI protocol
4)
Knowledge on ARM9 CPU core and AHB bus
5)
Knowledge on DDR3/LPDDR2
6)
Knowledge on AES and BCH ECC will be a plus
Position 2:
1)
Familiar with eMMC protocol
2)
3)
Knowledge on BCH ECC
某外资微电子公司,有兴趣可发简历至cissy_pq@163.com(在上海或者北京工作)
GMT+8, 2025-12-14 18:41 , Processed in 0.022645 second(s), 6 queries , Gzip On, Redis On.
