查看: 3659|回复: 2
[求助] ICC615平台数模混合仿真
发表于 2016-7-4 10:45:00 | 显示全部楼层 |阅读模式
数模混合仿真报错:Error found by UltraSim.    ERROR (USIM-12701): The UltraSim-Verimix (mixed mode) simulator option is
        not compatible with 64-bit platforms. The UltraSim simulator will exit
        the current session. Either run the simulation on a 32-bit platform or
        turn off the UltraSim-Verimix option before running the simulation
求大神解答;
 楼主| 发表于 2016-7-4 15:19:23 | 显示全部楼层
发表于 2016-8-27 22:26:54 | 显示全部楼层
貌似是不支持64位  换个32位版本试试
GMT+8, 2025-12-25 07:46 , Processed in 0.598965 second(s), 6 queries , Gzip On, Redis On.
