查看: 2910|回复: 6
[求助] 写的一个24s倒计时,怎么输出总不对,求解答
发表于 2016-3-22 15:32:08 | 显示全部楼层 |阅读模式
顶层:module digital(timerh,timerl,over,reset,stop,clk    );
output [6:0] timerh;
output [6:0] timerl;
output over;
input stop;
input reset;
input clk;
wire [1:0]H;
wire [3:0]L;
wire clk_1;
fenpin uut1(clk,clk_1);
basketballtimer uut2(over,H,L,reset,stop,clk_1);
cd4511  uut3(timerh[6:0],{2'b00,H[1:0]});
cd4511  uut4(timerl[6:0],L[3:0]);
endmodule
分频:module fenpin(clk,clk_1
input clk;
output clk_1;
reg [1:0] cnt;
reg clk_1;
always @(posedge clk)
begin
  if(cnt==2'b1_1001_0000_0000_0000_0000)
  begin
    clk_1<=~clk_1;
cnt<=0;
  end
  else
    cnt<=cnt+1;
end
endmodule
计时:module basketballtimer(over,H,L,reset,stop,clk_1
output over;
output [1:0]H;
output [3:0]L;
input reset;
input stop;
input clk_1;
reg [4:0]Q;
assign over=(Q==5'd0);
assign H=Q/10;
assign L=Q%10;
always@(posedge clk_1 or negedge reset or negedge stop)
begin
  if(~reset)
    Q<=5'd23;
  else
  begin
    if(~stop)
   Q<=Q;
else
begin
   if(Q>5'd0)
  Q<=Q-1'b1;
else
  Q<=Q;
end
  end
end
endmodule
显示:
module cd4511(Y,A
output reg [6:0]Y;
input [3:0]A;
always @(*)
begin
  case(A)
  4'd0:Y<=7'b1000_000;
  4'd1:Y<=7'b1111_001;
  4'd2:Y<=7'b0100_100;
  4'd3:Y<=7'b0110_000;
  4'd4:Y<=7'b0011_001;
  4'd5:Y<=7'b0010_010;
  4'd6:Y<=7'b0000_010;
  4'd7:Y<=7'b1111_000;
  4'd8:Y<=7'b0000_000;
  4'd9:Y<=7'b0010_000;
  default:Y<=7'b1000_000;
  endcase
end
endmodule
testbench:
module tgghh;
// Inputs
reg reset;
reg stop;
reg clk;
// Outputs
wire [6:0] timerh;
wire [6:0] timerl;
wire over;
// Instantiate the Unit Under Test (UUT)
digital uut (
.timerh(timerh),
.timerl(timerl),
.over(over),
.reset(reset),
.stop(stop),
.clk(clk)
initial begin
clk=0;
reset=1;
stop=1;
#10 reset=0;
#20 reset=1;
#200 stop=0;
#50  stop=1;
@(posedge over);
#20 $stop;
end
always #5 clk=~clk;
endmodule
 楼主| 发表于 2016-3-22 15:52:32 | 显示全部楼层
它的仿真图像输出一直是23
 楼主| 发表于 2016-3-22 15:53:38 | 显示全部楼层
 楼主| 发表于 2016-3-22 16:09:06 | 显示全部楼层
懂了,我的那个分频的不对,在仿真时不应该这样,实际中才应该那样写
发表于 2016-3-23 08:35:27 | 显示全部楼层
分频的计数器位宽都不匹配啊!
 楼主| 发表于 2016-3-23 09:24:31 | 显示全部楼层
回复 5# 金雕
那个是我修改了之后,没改回来,之前是reg [24:0] 也是不对的
发表于 2016-3-23 09:48:24 | 显示全部楼层
学习了
GMT+8, 2025-11-7 00:25 , Processed in 0.025407 second(s), 6 queries , Gzip On, Redis On.
