楼主: liaozhoulin
[求助] 有人有0.35um的hspice工艺库么?
发表于 2018-1-5 02:29:53 | 显示全部楼层
Nice!
发表于 2018-1-5 09:04:59 | 显示全部楼层
回复 7# zhiyuli
1. Selecingt the Spice parameter file by "path".
2. Selecting the specific device (process) corner by library name.
Refer to the following lines (pasted from a sample SPICE simulation deck) for examples:
   .lib "C:\MyProject\v18_010518\sim\Model\mm018.l" tt
   .lib "C:\MyProject\v18_010518\sim\Model\mm018.l" tt_3v
   .lib "C:\MyProject\v18_010518\sim\Model\mm018.l" dio
   .lib "C:\MyProject\v18_010518\sim\Model\mm018.l" dio3
   .lib "C:\MyProject\v18_010518\sim\Model\mm018.l" tt_res
The above five lines choose
(a) typical 1.8V MOS devices,
(b) typical 3.3V MOS devices,
(c) typical LV diodes,
(d) 3.3V diodes, and
(e) typical resistor library models (with specific process corners) from the same SPICE parameter file "mm018.l" located in the "C:\MyProject\v18_010518\sim\Model\" directory.
Good luck!
 楼主| 发表于 2018-5-21 07:06:30 | 显示全部楼层
呵呵哈哈哈或或
发表于 2018-6-29 11:08:21 | 显示全部楼层
非常感谢,很好的东西,正需要呢
发表于 2020-11-20 21:04:15 | 显示全部楼层
非常感谢!
发表于 2021-8-11 09:29:07 | 显示全部楼层
populbb 发表于 2016-1-13 22:00
回复 1# liaozhoulin
感谢分享
GMT+8, 2025-12-31 08:49 , Processed in 0.019645 second(s), 4 queries , Gzip On, Redis On.
