查看: 3427|回复: 4
[求助] 读spef时tie cell 的error,warning
发表于 2015-10-11 20:35:23 | 显示全部楼层 |阅读模式
大家好,小弟用starrc抽取spef后用pt读入spef,发现出现很多tie cell 的error和warning,写出pt.v文件之前,change name -rules verilog -hierarchy了,不知道为什么这么多tiecell 的errror和warnin,如下所示:Error: Cannot find port/pin 'TIEL_HVT!U527/ZN' in design 'oc8051_top' (DES-002)
Error: Cannot find net 'TIEL_HVT!U899_net' in design 'oc8051_top' (DES-002)
Warning: Coupling capacitor (buff[43]:1119 TIEL_HVT!U899_net:637 7.16442e-05) on net buff[43]
is discarded because net 'TIEL_HVT!U899_net:637' could not be found (PARA-040)
Warning: Coupling capacitor (oc8051_indi_addr1_buff_reg_0__2_:SI TIEL_HVT!U899_net:637 3.21245e-05) on net buff[43]
Warning: Coupling capacitor (buff[42]:1393 TIEL_HVT!U899_net:637 2.82029e-05) on net buff[42]
Error: Cannot find port/pin 'TIEL_HVT!U887/ZN' in design 'oc8051_top' (DES-002)
Warning: Invalid coupling capacitor (buff[42]:1393 TIEL_HVT!U887:ZN 0.00134069) on net buff[42]:
node 'TIEL_HVT!U887:ZN' could not be found (PARA-043)
Warning: Invalid coupling capacitor (buff[42]:986 TIEL_HVT!U887:ZN 6.66862e-05) on net buff[42]:
Warning: Coupling capacitor (buff[42]:986 TIEL_HVT!U899_net:637 2.94531e-05) on net buff[42]
Warning: Coupling capacitor (oc8051_indi_addr1_buff_reg_5__2_N TIEL_HVT!U899_net:637 2.36647e-06) on net buff[42]
Error: Cannot find net 'TIEH_HVT!U7_net' in design 'oc8051_top' (DES-002)
发表于 2015-10-11 22:19:17 | 显示全部楼层
change_names了,save_mw_cel了么,然后再starxt extraction
 楼主| 发表于 2015-10-11 22:56:02 | 显示全部楼层
回复 2# icfbicfb
  出  pt.v之前change_name了,然后要save_mw_cel ?之后没有save_mw_cel,有什么影响?。。。
发表于 2015-10-12 09:59:17 | 显示全部楼层
要的,starxt抽取的是mw cel view本身啊,如果不save,他怎么知道你change name等操作了呢
 楼主| 发表于 2015-10-12 10:15:13 | 显示全部楼层
回复 4# icfbicfb
   谢谢版主,昨天想了下确实要保存cel,
GMT+8, 2025-12-16 18:02 , Processed in 0.021243 second(s), 6 queries , Gzip On, Redis On.
