查看: 4187|回复: 3
Improve ESD Robustness in 130nm (Ming-Dou Ker)
发表于 2007-5-5 10:50:31 | 显示全部楼层 |阅读模式
Dummy-Gate Structure to Improve ESD Robustness in a Fully-Salicided
130-nm CMOS Technology without Using Extra Salicide-Blocking Mask
Hsin-Chyh Hsu and Ming-Dou Ker
Nanoelectronics and Gigascale Systems Lab.
Institute of Electronics, National Chiao-Tung University, Taiwan
E-mail: HCHsu@ieee.org
Abstract
NMOS with dummy-gate structure is proposed to
significantly improve electrostatic discharge (ESD)
robustness in a fully-salicided CMOS technology. By using
this structure, ESD current is discharged far away from
the salicided surface channel of NMOS, therefore the
NMOS can sustain a much higher ESD level. The HBM
(MM) ESD robustness of the NMOS with dummy-gate
structure (W/L = 480 μm/0.18 μm) has been successfully
improved from 0.5 kV (125 V) to 1.5 kV (325 V) in a
130-nm fully-salicided CMOS process. Under the same
layout area of the gate-grounded NMOS (ggNMOS), HBM
(MM) ESD level can be improved over 300% (260%) by
the proposed dummy-gate structure. The proposed
dummy-gate structure is fully process compatible to
general salicided CMOS processes without additional
mask, which is very cost-efficient for application in the IC
products.
ISQED2006_H-C Hsu.pdf
287.12 KB, 下载次数: 51 , 下载积分: 资产 -2 信元, 下载支出 2 信元
发表于 2007-5-8 00:15:43 | 显示全部楼层
thank you
发表于 2007-6-11 13:31:41 | 显示全部楼层
good stuff
发表于 2011-5-17 06:41:07 | 显示全部楼层
谢谢分享
GMT+8, 2025-12-30 01:20 , Processed in 0.023666 second(s), 7 queries , Gzip On, Redis On.
