查看: 2626|回复: 5
[招聘] Synopsys 北京急招Program Manager
发表于 2014-12-25 17:17:59 | 显示全部楼层 |阅读模式
欢迎把简历发到:zhuqin.tang@synopsys.com
Job Description and Requirements:
Manages IP development for key programs and successfully executes the programs against established commitments.  Acts as the focal point of contact and a coordinator and manages all external and internal communications to cross-functional teams spanning geographical and organizational boundaries. Plans and directs schedules; identifies and escalates issues; drives problems to resolution; and identifies and manages risk. Programs include porting of different IPs to different process technology nodes. The position requires technical understanding of analog and digital design flows and methodologies, IC manufacturing process, and process technologies.
The program manager must have a strong background and proven track record in project management. The candidate must be able to organize interdepartmental activities ensuring completion of the project/program on schedule and with high quality. The individual must be able to manage multiple projects at the same time, recognize and mitigate risks, and work proactively on contingency plans. The candidate must be process-oriented with emphasis on clear and documented communication.
Minimum Requirements
Typically requires a BS with a minimum of 10+ years of relevant experience, Candidate must have a strong background and proven track record in program management in analog/digital design. Understanding IC manufacturing, process technology, design flow and sign off process is key. Having experience in dealing with and communicating at different levels of the organization is also key to this position. Exceptional verbal/written communication, leadership, interpersonal, and teamwork skills are a must.
Demonstrated ability to work independently and to create and meet schedules.
 楼主| 发表于 2014-12-26 09:43:33 | 显示全部楼层
自己顶~~
发表于 2014-12-26 14:28:17 | 显示全部楼层
帮忙顶一个
 楼主| 发表于 2014-12-29 16:31:45 | 显示全部楼层
顶~~~
发表于 2015-1-1 13:39:37 | 显示全部楼层
顶一个
回复 4# synopsysHR
 楼主| 发表于 2015-1-4 10:43:42 | 显示全部楼层
回复 5# zhanliwang
GMT+8, 2025-12-20 07:15 , Processed in 0.695033 second(s), 3 queries , Gzip On, Redis On.
