查看: 3060|回复: 8
[求助] » A 40 nm Fully Integrated 82 mW Stereo Headphone Module
发表于 2014-8-27 15:55:44 | 显示全部楼层 |阅读模式
» [url=]A 40 nm Fully Integrated 82 mW Stereo Headphone Module for Mobile Applications[/url]
Résumé:
An 82 mW fully integrated stereo ground-referenced headphone module is designed in 40 nm CMOS. Lower platform cost is enabled by integrating the headphone module on the same SoC as the baseband functions. Maintaining device reliability with direct battery hook-up and providing large output swing are major challenges for this work, and several techniques were employed to guarantee safe operation for all of the devices under various conditions. Area reduction techniques were utilized to reduce the die cost and achieve lower platform cost. The module supports direct battery hookup with a battery range from 3.1 to 4.5 V and achieves a minimum low frequency, i.e., 217 Hz, PSRR of 110 dB at the lowest battery voltage. Audio quality is preserved by achieving a dynamic range of 100 dB, THD+N of
84 dB at 10 mW output power, and 160
V pop-and-click noise level during power-up and power-down. The module occupies an area of 0.675 mm
on the SoC.
Auteurs: Abdelfattah, K.;Galal, S.;Mehr, I.;Chen, A.J.;Yu, C.;Tjie, M.;Tekin, A.;Jiang, X.;Brooks, T.L.;
Apparue dans: IEEE Journal of Solid-State Circuits
Date publication: 08.-2014, volume: 49, issue:8, pages: 1702 - 1714
Editeur: IEEE
 楼主| 发表于 2014-8-28 15:44:39 | 显示全部楼层
谁能帮忙下载?
今年8月份的jsscc
谢谢。
 楼主| 发表于 2014-8-28 16:04:27 | 显示全部楼层
zhao dao la
06797951.pdf
2.92 MB, 下载次数: 41 , 下载积分: 资产 -2 信元, 下载支出 2 信元
发表于 2014-8-29 14:42:43 | 显示全部楼层
不错不错,内容非常多
发表于 2014-8-29 19:13:43 | 显示全部楼层
下来看看
发表于 2014-8-29 20:08:00 | 显示全部楼层
发表于 2017-12-4 21:32:34 | 显示全部楼层
3xsharing
发表于 2017-12-5 00:48:22 | 显示全部楼层
Thank you. Interesting
发表于 2017-12-5 09:00:54 | 显示全部楼层
tks tks
GMT+8, 2025-12-27 08:15 , Processed in 0.025107 second(s), 7 queries , Gzip On, Redis On.
