查看: 11633|回复: 30
[招聘] Micron上海研发中心诚聘Analog Designer
发表于 2014-8-5 15:05:25 | 显示全部楼层 |阅读模式
尊敬的工程师们,你们好!Micron上海研发中心现诚聘Analog Designer 模拟电路设计师(半导体记忆电路设计,DRAM/闪存设计,模拟设计)。具体JD如下。欢迎你们将简历投递至rjing@micron.com。该职位面向有2年以上相关工作经验的工程师,非校园招聘,感谢关注!
Description
As an Analog Designer at Micron's Shanghai Design Center, you will work in a highly innovative and motivated design team using state of the art memory technologies to develop advanced NAND Flash Memory or DRAM. You will participate in VLSI circuit design and verification in the circuit areas such as data paths, control logic, IO circuit, charge pumps, regulators, bandgaps, op-amps, comparators and oscillators. You will also work closely with Micron's various design teams in US and other countries and leverage vast resources available through out Micron's global sites. Additionally, you will provide layout supervision, as well as optimize layout throughout post-layout simulations. As part of a multi-disciplinary team, you will participate in system-level modeling and simulation.
Qualifications
Successful candidates for this position will have:
- An in-depth knowledge of device physics.
- 3 years of experience
- Strong analog design skills.
- Process background.
- A high level of self-motivation.
- The ability to be a team player.
- Experience with memory design, such as SRAM, DRAM, and CAM (preferred).
- Familiarity with the Cadence design environment.
- Experience with transistor-level simulators such as SPICE.
- Experience with circuits such as charge pumps, regulators, voltage and current references, op-amps, comparators, oscillators, IOs.
- The ability to write RTL code and participate in logic verification is a plus.
Education
MS in Microelectronics is required (PhD preferred).
发表于 2014-8-5 18:27:16 | 显示全部楼层
这个要求跟刚才那个龙岗的形成巨大反差
要求最好博士且能够写数字代码的模拟工程师 还有做过偏门存储器
觉得龙岗那个如果招本科可以压到5-6k 比旁边的比亚迪低点
这个全满足至少开到20k才对得起相应的技能经验学历
发表于 2014-8-5 22:30:39 | 显示全部楼层
前段时间听说镁光准备开发ReRAM和MRAM,楼主能否确认一下消息是否属实?
发表于 2014-8-6 07:48:40 | 显示全部楼层
这个公司怎么样?曾今收到过面试通知,太忙了就没去,不知道有没有2万一个月的
发表于 2014-8-6 08:42:43 | 显示全部楼层
回复 4# Vdsat
    老牌顶级存储器公司,后来在英飞凌和三星的挤压下市场萎缩。沉寂了一段时间,上次听说就是准备搞mram了,但这是不成功便成仁的东西。。。你自己判断吧。
 楼主| 发表于 2014-8-6 09:08:03 | 显示全部楼层
各位早,美光上海研发中心正在加速发展,欢迎将简历发送至rjing@micron.com,我会尽快回复。感谢各位的关注!
发表于 2014-8-6 09:21:36 | 显示全部楼层
回复 4# Vdsat
   美光在亏钱 不一定能给的出20000 搞不好过几年完蛋了 由于三星和英飞凌在国内研发职位不多 所以一旦它完蛋也是可以酝酿出微软裁员诺基亚那样的残酷的 象内存这种小众分支 市场容量不够 大厂裁员几百人的时候 基本只低薪转行的
发表于 2014-8-6 10:21:51 | 显示全部楼层
回复 7# chengdumicro
    内存和cpu一样,主要几个大公司垄断,但不能算小分支。
发表于 2014-8-6 11:46:44 | 显示全部楼层
回复 7# chengdumicro
   别吓我啊,我很胆小的
发表于 2014-8-6 11:47:21 | 显示全部楼层
回复 5# hszgl
   这个也是风险与机遇并存的
GMT+8, 2025-12-20 05:21 , Processed in 0.020487 second(s), 6 queries , Gzip On, Redis On.
