查看: 4081|回复: 8
mmsim12.1安装问题
发表于 2014-7-24 15:38:24 | 显示全部楼层 |阅读模式
平台是RHEL6.5 x64,Cadence IC616 x64,IC616需要的lib已经都下好了,可以正常打开。安装了64位的mmsim12.1,license和环境变量设置同IC616,感觉没问题。
但是在Cadence中开启ADE的仿真,就会跳出提示:
values for following varaible is not set for the simulator run
点继续,仿真没有进行,报错:
ERROR (ADE-3036): Errors encountered during simulation. The simulator run log has not been generated.
        Possible cause could be an invalid command line option for the version of the simulator
        you are running. Choose Setup->Environment and verify that the command line options
        specified in the userCmdLineOption field are supported for the simulator.
        Alternatively, run the simulator standalone using the runSimulation file in the netlist
        directory to know the exact cause of the error.
仿真环境已经设置为64位!!!不明白这个错是怎么回事
发表于 2014-7-24 18:20:37 | 显示全部楼层
回复 1# qianxuan
run spectre in terminal and send me output
发表于 2014-11-12 20:11:30 | 显示全部楼层
楼主问题解决了吗?求解决方法~~
发表于 2015-5-27 14:28:07 | 显示全部楼层
有没有解决的办法啊?
发表于 2015-8-20 16:14:53 | 显示全部楼层
回复 1# qianxuan
   能否给个×64的IC616网盘地址?
发表于 2016-5-20 13:35:58 | 显示全部楼层
回复 1# qianxuan
请问环境变量怎么设置啊,我安装的ic610,可以画图,但是仿真时到最后一步,无法运行,提示没有工艺库路径,使我环境变量没设置的原因吗?请小哥赐教!
发表于 2016-5-22 05:19:36 | 显示全部楼层
好东西,感谢分享!!
发表于 2016-6-22 21:40:24 | 显示全部楼层
楼主MMSIM在哪里下载的
发表于 2016-6-23 22:38:30 | 显示全部楼层
MMSIM是安装的还是绿色版的
GMT+8, 2025-12-23 07:12 , Processed in 0.024194 second(s), 7 queries , Gzip On, Redis On.
