查看: 12351|回复: 39
[资料] MicroCMOS Design
发表于 2014-6-3 11:00:04 | 显示全部楼层 |阅读模式
  • MicroCMOS DesignSeries:
    Circuits and Electrical Engineering
    Published:
    September 14, 2011 by CRC Press
    Content:
    434 Pages | 478 Illustrations
    Author(s):
    Bang-Sup Song
MicroCMOS Design covers key analog design methodologies with an emphasis on analog systems that can be integrated into systems-on-chip (SoCs). Starting at the transistor level, this book introduces basic concepts in the design of system-level complementary metal-oxide semiconductors (CMOS). It uses practical examples to illustrate circuit construction so that readers can develop an intuitive understanding rather than just assimilate the usual conventional analytical knowledge.
As SoCs become increasingly complex, analog/radio frequency (RF) system designers have to master both system- and transistor-level design aspects. They must understand abstract concepts associated with large components, such as analog-to-digital converters (ADCs) and phase-locked loops (PLLs). To help readers along, this book discusses topics including:
  • Amplifier basics & design
  • Operational amplifier (Opamp)
  • Data converter basics
  • Nyquist-rate data converters
  • Oversampling data converters
  • High-resolution data converters
  • PLL basics
  • Frequency synthesis and clock recovery
Table of Contents
Amplifier Basics
Driving-Point and Transfer Functions
Frequency Response
Stability Criteria
Operational Amplifier (Opamp) in Negative Feedback
Phase Margin
Transient Response
Feedback Amplifier
Feedback Effect
Left-Half or Right-Half Plane Zero
Stability of Feedback Amplifiers
Amplifier Design
Abstract Low-Frequency Model of Transistors
Driving-Point Resistances at Low Frequencies
Resistance Reflection Rules
Three Basic Amplifier Configurations
Nine Amplifier Combinations
Differential Pair
Gain Boosting
Biasing
Voltage and Current Sources
Small-Signal Model of the Operational Amplifier
Opamp Frequency Compensation
Phase Margin of Two-Stage Miller-Compensated Opamps
Right-Half Plane Zero Cancellation in Two-Stage Opamps
Transient Response of Opamp in Feedback
Opamp Design Examples
Common-Mode Feedback
Offset Cancellation
Opamp Input Capacitance
Opamp Offset
Opamp Noise
Opamp Common-Mode Rejection
Data Converter Basics
Analog-to-Digital Converter Basics
Sample and Hold
Flash Analog-to-Digital Converter
Comparator
ADC Testing
Averaging and Interpolation Techniques
Low-Voltage Circuit Techniques
Digital-to-Analog Converter Basics
Nyquist-Rate Data Converters
Analog-to-Digital Converter Architectures
Slope-Type ADC
Successive Approximation Register ADC
Subranging and Multistep ADC
Pipelined ADC
Folding ADC
Other ADCs
Stand-Alone DACs
Oversampling Data Converters
Concept of Quantizer in Feedback
ΔΣ Modulator
High-Order Architectures
Discrete-Time (DT) versus Continuous-Time (CT) Modulators
Discrete-Time Modulator Design
Band-Pass Modulator Design
Continuous-Time Modulator Design
Interpolative Oversampling DAC
High-Resolution Data Converters
Nonlinearity of the Analog-to-Digital Converter
Evolution of High-Resolution ADC Design
Digital Calibration of ADC
Digital Background Calibration
Digital Processing for Gain Nonlinearity
Calibration by Zero-Forcing Least-Mean-Square Feedback
Calibration of Time-Interleaving ADC
Calibrated Continuous-Time (CT) ΔΣ Modulators
Calibration of Current-Steering DAC
Phase-Locked Loop Basics
Phase Noise
Phase-Locked Loop Operation
Phase Noise Transfer Function
Phase Detector
Charge-Pumped Phase-Locked Loop
PLL Bandwidth Constraints
High-Q LC VCO
Low-Q Ring-Oscillator VCO
Prescaler
Frequency Synthesis and Clock Recovery
Phase-Locked Loop Applications
Digital PLL
Frequency Synthesis
Spur-Canceled Fractional-N Frequency Synthesizer
Data Symbols
Data Channel Equalization
Clock and Data Recovery
NRZ Phase Detector
microcmos-design.pdf (11.76 MB , 下载次数: 730 )
发表于 2014-6-3 22:01:24 | 显示全部楼层
沙发,感谢楼主
发表于 2014-6-3 22:02:15 | 显示全部楼层
感謝 ~~~
发表于 2014-6-4 21:00:20 | 显示全部楼层
great job !
发表于 2014-6-4 21:45:18 | 显示全部楼层
谢谢分享
发表于 2014-6-5 12:00:44 | 显示全部楼层
真太感谢。
发表于 2014-6-5 12:15:16 | 显示全部楼层
great!
发表于 2014-6-5 12:26:49 | 显示全部楼层
顶一下~~~~~~~~~~~~~~~~~~~~~
发表于 2014-6-5 12:30:00 | 显示全部楼层
什么时候变蓝领了。。。。。。
发表于 2014-6-5 12:36:05 | 显示全部楼层
这本书看起来象个大杂烩,什么都介绍点,什么都介绍的不详细。
GMT+8, 2025-12-23 22:32 , Processed in 0.029768 second(s), 6 queries , Gzip On, Redis On.
