查看: 2469|回复: 0
[求助] 请问下面这段代码在DFT中reset_n端报错要怎么解决
发表于 2014-4-20 14:29:35 | 显示全部楼层 |阅读模式
always @ (posedge clk)
if (reset_n == 0)
run_before <= 0;
else if (cavlc_decoder_state == `run_before_LUT)
case (zerosLeft)
0:run_before <= 0;//special case added for "total_zeros==0"
1:run_before <= (BitStream_buffer_output[15] == 0)? 4'd1:4'd0;
2:if      (BitStream_buffer_output[15] == 1)        run_before <= 0;
  else if (BitStream_buffer_output[15:14] == 2'b01)
run_before <= 1;
  else                                              run_before <= 2;
3:case (BitStream_buffer_output[15:14])
2'b00:run_before <= 3;
2'b01:run_before <= 2;
2'b10:run_before <= 1;
2'b11:run_before <= 0;
  endcase
4:case (BitStream_buffer_output[15:14])
2'b00:run_before <= (BitStream_buffer_output[13] == 1)? 4'd3:4'd4;
  endcase
5:case (BitStream_buffer_output[15:14])
2'b00:run_before <= (BitStream_buffer_output[13] == 1)? 4'd4:4'd5;
2'b01:run_before <= (BitStream_buffer_output[13] == 1)? 4'd2:4'd3;
  endcase
6:casex (BitStream_buffer_output[15:13])
3'b11x:run_before <= 0;
3'b000:run_before <= 1;
3'b001:run_before <= 2;
3'b011:run_before <= 3;
3'b010:run_before <= 4;
3'b101:run_before <= 5;
3'b100:run_before <= 6;
  endcase
default:
case (BitStream_buffer_output[15:13])
3'b000:run_before <= run_of_zeros_len + 3;
3'b111:run_before <= 0;
3'b110:run_before <= 1;
3'b101:run_before <= 2;
3'b100:run_before <= 3;
3'b011:run_before <= 4;
3'b010:run_before <= 5;
3'b001:run_before <= 6;
endcase
endcase
GMT+8, 2025-12-12 22:35 , Processed in 0.013586 second(s), 6 queries , Gzip On, Redis On.
