查看: 19209|回复: 17
[求助] TSMC DRC及LVS 警告问题
发表于 2014-4-4 19:08:49 | 显示全部楼层 |阅读模式
基于TSMC做了一个运放的版图,进行DRC检查时出现很多下述错误:
Check CSR.R.1.NWELLi {@ If customer request TSMC to add CSR,seal ring and CDU,empty areas at 4 chips corners must be reserved and no layout is allowed inside.   EMPTY_AREA AND NWELLi}
Check CSR.R.1.POPLYGi {@ If customer request TSMC to add CSR,seal ring and CDU,empty areas at 4 chips corners must be reserved and no layout is allowed inside.   EMPTY_AREA AND POPLYGi}
Check CSR.R.1.PIMPi {@ If customer request TSMC to add CSR,seal ring and CDU,empty areas at 4 chips corners must be reserved and no layout is allowed inside.   EMPTY_AREA AND PIMPi}
Check CSR.R.1.NIMPi {@ If customer request TSMC to add CSR,seal ring and CDU,empty areas at 4 chips corners must be reserved and no layout is allowed inside.   EMPTY_AREA AND NIMPi}
Check CSR.R.1.CONTi {@ If customer request TSMC to add CSR,seal ring and CDU,empty areas at 4 chips corners must be reserved and no layout is allowed inside.   EMPTY_AREA AND CONTi}
忽略上述错误做LVS时,虽然露出笑脸,验证通过,但是在 Exteaction Results中提示下述Warning:
WARNING: Invalid PATHCHK request " ! POWER": no POWER nets present, operation aborted.
WARNING: Invalid PATHCHK request " ! GROUND": no GROUND  nets present, operation aborted.
WARNING: Invalid PATHCHK request "GROUND && ! POWER": no POWER nets present, operation aborted.
WARNING: Invalid PATHCHK request "POWER && ! GROUND": no POWER nets present, operation aborted.
WARNING: Invalid PATHCHK request "! POWER && ! GROUND": no POWER nets present, operation aborted.
哪位大侠遇到过这种问题,请指教
 楼主| 发表于 2014-4-6 21:55:14 | 显示全部楼层
LVS的warning已解决,是因为自己在电源和地命名的时候用的“VDDA”和“GNDA” 在.lvs文件中不识别,更改.lvs文件把这连个符号加进去就ok了。 DRC的问题依然待解决......
 楼主| 发表于 2014-4-8 15:51:30 | 显示全部楼层
继续求解答......
发表于 2014-4-19 17:34:28 | 显示全部楼层
highlight的地方如果要求加CSR,seal ring and CDU,4个角的地方就空着不能画layout
发表于 2014-4-24 12:52:48 | 显示全部楼层
楼主问题解决了吗?我也遇到同样的DRC问题,不知道该怎么弄。希望会的大神们不吝赐教,谢谢
发表于 2014-8-25 16:05:51 | 显示全部楼层
同遇到这个问题,不知楼主解决没有,或者有没有大神帮忙解决一下,谢谢
发表于 2014-8-26 11:08:20 | 显示全部楼层
define full_chip 关闭, 如果不是chip是block的话,请不要开这个选项
检查corner pad的,有corner pad才行
发表于 2014-8-26 15:40:37 | 显示全部楼层
原则上chip corner的区域是不可以放一些电路功能的layout,除非之前有以身试法过
发表于 2014-8-26 15:51:11 | 显示全部楼层
corner很有讲究的, 不是随便那么设计的,
发表于 2014-9-13 13:57:07 | 显示全部楼层
涨涨人气
GMT+8, 2025-12-24 12:25 , Processed in 0.025709 second(s), 5 queries , Gzip On, Redis On.
