查看: 3054|回复: 1
[原创] FreeNX在RHEL5.4下的安装
发表于 2014-1-28 13:11:05 | 显示全部楼层 |阅读模式
1)安装expect
   yum install expect;
   或者下载相应rpm并安装:expect-5.43.0-5.1.x86_64.rpm
                          expect-devel-5.43.0-5.1.x86_64.rpm
                          expecttk-5.43.0-5.1.x86_64.rpm
2) 下载nx和freenx-server的src rpm:
   http://dl.atrpms.net/all/nx-3.3.0-38.src.rpm
   http://dl.atrpms.net/all/freenx-server-0.7.3-18.src.rpm
3)rebuild rpm
   rpmbuild --rebuild nx-3.3.0-38.src.rpm
   rpmbuild --rebuild freenx-server-0.7.3-18.src.rpm
   相应rpm被保存到:/usr/src/redhat/RPMS/x86_64/nx-3.3.0-38.rpm
                    /usr/src/redhat/RPMS/x86_64/freenx-server-0.7.3-18.rpm
4) 安装rpm
   rpm -ivh /usr/src/redhat/RPMS/x86_64/nx-3.3.0-38.rpm
   rpm -ivh /usr/src/redhat/RPMS/x86_64/freenx-server-0.7.3-18.rpm
5)更改ssh配置
   打开/etc/ssh/sshd_config
   更改 # AuthorizedKeysFile .ssh/authorized_keys 为AuthorizedKeysFile .ssh/authorized_keys2
   重启ssh:/etc/init.d/sshd restart
6) 更改shell路径
   export PATH=/usr/libexec/nx:$PATH
7)安装freenx
   nxsetup --install
   在接下来的对话中选择n;
8)更改node.config
   vi /etc/nxserver/node.conf
   更改# ENABLE_PASSDB_ATUENTICATION="0" 为 ENABLE_PASSDB_ATUENTICATION="1"
9) 运行nxkeygen
   nxkeygen
   key会被保存到:/var/lib/nxserver/home/.ssh/client.id_dsa.key
10)nxserver相关命令
    nxserver --help;
    nxserver --adduser(listuser passwd status start restart ...)
    (在测试过程中,似乎所有系统用户不用添加,均可登录,密码为系统密码)
11)安装nx客户端
    下载并安装nxclient-3.4.0-5.exe或者其他版本
12) 导入key
    安装成功后,将/var/lib/nxserver/home/.ssh/client.id_dsa.key 拷贝到
    c:/Program Files/NX Client for Windows\share\Keys
13) 创建session:
     运行nx client:创建session,
     填写session name,host ip,port(22),desktop(unix gnome),分辨率
     弹出的登录窗口中:config->general->keys导入client.id_dsa.key,点击保存
14)运行session
参考:
http://blog.yibi.org/2011/08/10/installing-freenx-on-red-hat-enterprise-linux
http://blog.chinaunix.net/uid-20776139-id-1846887.html
http://www.oschina.net/question/12_7652
发表于 2014-12-3 05:33:33 | 显示全部楼层
xie xie !
GMT+8, 2025-12-16 06:38 , Processed in 0.017541 second(s), 5 queries , Gzip On, Redis On.
