查看: 2669|回复: 5
[求助] about mfg grid
发表于 2010-7-22 14:00:20 | 显示全部楼层 |阅读模式
Hi ,all
Now we use 1um technology , and the mfg grid is 0.005um in tech file.
I think it's too small for 1um technology, should I set snap spacing to 0.005 or a bigger one?
thanks for your attention and expect your reply~~
 楼主| 发表于 2010-7-22 15:35:12 | 显示全部楼层
no one help me????????????????
 楼主| 发表于 2010-7-23 09:09:38 | 显示全部楼层
期待回答~~~
发表于 2010-9-19 12:54:19 | 显示全部楼层
1# langzijian2006
I think you can set the snap spcing to 0.005*N,where N is one integer. So you can set it to 0.5 or 1 ,and so on.
发表于 2010-9-19 13:43:43 | 显示全部楼层
只要是0.005um的整数倍就行。
以你画着方便为主。
发表于 2010-9-19 14:47:33 | 显示全部楼层
请问:什么是mfg???
画版图用的?不好意思,第一次听说。
GMT+8, 2025-12-30 09:36 , Processed in 0.021969 second(s), 6 queries , Gzip On, Redis On.
