查看: 7862|回复: 12
[求助] LVS求助
发表于 2014-1-25 20:34:46 | 显示全部楼层 |阅读模式
在做LVS时,ICC中的LVS通过了,但是在Calibre中却报出了错误,有很多missing connection的net错误。另外还有一些instances错误:MOS管的衬底没有直接连到VDD或VSS上,而是连到了一个二极管上,网表中我是直接把VNW和VPW改成了VDD和VSS,实在不知道问题出在哪里,求高人解答。我的部分lvs报告如下:
                  CELL COMPARISON RESULTS ( TOP LEVEL )
                    #           #     INCORRECT     #
  Error:    Different numbers of nets (see below).
  Error:    Different numbers of instances (see below).
  Error:    Connectivity errors.
  Error:    Property errors.
  Warning:  Unbalanced smashed mosfets were matched.
  Warning:  Ambiguity points were found and resolved arbitrarily.
LAYOUT CELL NAME:         execution_array_top
SOURCE CELL NAME:         execution_array_top
INITIAL NUMBERS OF OBJECTS
                Layout    Source         Component Type
Ports:             29        29
Nets:          201945    201590    *
Instances:     515528    450968    *    M (4 pins)
                  6463         0    *    D (2 pins)
Total Inst:    521991    450968
NUMBERS OF OBJECTS AFTER TRANSFORMATION
Ports:             29        29
Nets:          110527    108366    *
Instances:     215866    215864    *    M (4 pins)
                 52198     52198         SM2 (4 pins)
                  4578      4578         SM3 (5 pins)
                   233       233         SM4 (6 pins)
                  2196      2196         SPM_2_1 (5 pins)
                   279       279         SPM_2_1_1 (6 pins)
                  5972      5972         SPM_2_2 (6 pins)
                   946       946         SPM_2_2_1 (7 pins)
                    11        11         SPM_2_2_2 (8 pins)
                   339       339         SPM_3_1 (6 pins)
                    57        57         SPM_3_2 (7 pins)
Total Inst:    282675    282673
       * = Number of objects in layout different from number in source.
                                 INCORRECT OBJECTS
LEGEND:
  ne  = Naming Error (same layout name found in source
        circuit, but object was matched otherwise).
                                   INCORRECT NETS
DISC#  LAYOUT NAME                                               SOURCE NAME
  1    Net VDD                                                   VDD
       ** missing connection **                                  XU14/MPA1010:b
       ** missing connection **                                  Xc_a2emitter_w_data_00_r_reg_25_/MPOEN034:b
       ** missing connection **                                  Xc_a2emitter_w_data_00_r_reg_25_/MPOEN:b
       ** missing connection **                                  Xc_a2emitter_w_data_00_r_reg_25_/MPA106:b
       ** missing connection **                                  Xc_a2emitter_w_data_00_r_reg_25_/MPA1042:b
       ** missing connection **                                  Xc_a2emitter_w_data_00_r_reg_25_/MPA1038:b
  2    Net VSS                                                   VSS
       X343/M1692(256.900,209.080):b                             ** missing connection **
       X343/M1692(256.900,209.080):s                             ** missing connection **
  3    Net 2705                                                  Xexecution_array_inst/Xx_ea_cluster_00/Xx_ea_packet_router_wrap/n29
       X343/M15083(256.900,207.800):g                            ** missing connection **
       X343/M1692(256.900,209.080):g                             ** missing connection **
   7    Net X351/634                                              Xexecution_array_inst/Xx_ea_cluster_00/Xx_ea_packet_router/clk_gated_r_s
       (SM2):input                                               ** missing connection **
         X351/M4503(31.175,219.070):g
         X351/M4500(32.105,218.810):g
         X351/M4493(30.975,219.925):g
         X351/M4490(31.905,220.240):g
       X351/M10553(32.345,218.020):g                             ** missing connection **
                                 INCORRECT INSTANCES
51    X329/M10191(692.565,519.800)  M(lvtpfet)                  Xexecution_array_inst/Xx_execution_unit/Xx_fft_8p/Xfft_8p_stage1_inst/Xfft_8p_mul1_inst/Xicc_place434/MPA1_2  M(lvtpfet)
         g: 4335                                                   g: Xexecution_array_inst/Xx_execution_unit/Xx_fft_8p/Xfft_8p_stage1_inst/Xfft_8p_mul1_inst/sub_0_root_sub_0_root_sub_85_n117
         b: X329/1913                                              ** no similar net **
         ** VDD **                                                 b: VDD
52    X329/M10192(692.825,519.800)  M(lvtpfet)                  Xexecution_array_inst/Xx_execution_unit/Xx_fft_8p/Xfft_8p_stage1_inst/Xfft_8p_mul1_inst/Xicc_place434/MPA2_2  M(lvtpfet)
         g: X329/632                                               g: Xexecution_array_inst/Xx_execution_unit/Xx_fft_8p/Xfft_8p_stage1_inst/Xfft_8p_mul1_inst/N207
         ** VDD **                                                 b: VDD
53    X329/M10968(835.225,542.490)  M(lvtpfet)                  Xexecution_array_inst/Xx_execution_unit/Xx_fft_16p/Xfft_16p_stage1_inst/Xfft_16p_mul1_inst/Xadd_0_root_sub_0_root_add_147_U183/MPA2_4  M(lvtpfet)
         g: X329/1663                                              g: Xexecution_array_inst/Xx_execution_unit/Xx_fft_16p/Xfft_16p_stage1_inst/Xfft_16p_mul1_inst/N967
         b: X329/1925                                              ** no similar net **
         ** VDD **                                                 b: VDD
54    X329/M10967(835.485,542.490)  M(lvtpfet)                  Xexecution_array_inst/Xx_execution_unit/Xx_fft_16p/Xfft_16p_stage1_inst/Xfft_16p_mul1_inst/Xadd_0_root_sub_0_root_add_147_U183/MPA1_4  M(lvtpfet)
         g: X329/1369                                              g: Xexecution_array_inst/Xx_execution_unit/Xx_fft_16p/Xfft_16p_stage1_inst/Xfft_16p_mul1_inst/N490
         ** VDD **                                                 b: VDD
55    X329/M11786(892.025,547.290)  M(lvtpfet)                  Xexecution_array_inst/Xx_execution_unit/Xx_fft_16p/Xfft_16p_stage1_inst/Xfft_16p_mul1_inst/XU1302/MPA2_4  M(lvtpfet)
         g: 284                                                    g: Xexecution_array_inst/Xx_execution_unit/Xx_fft_16p/Xfft_16p_stage1_inst/Xfft_16p_mul1_inst/n4486
         b: X329/1929                                              ** no similar net **
         ** VDD **                                                 b: VDD
56    X329/M11785(892.285,547.290)  M(lvtpfet)                  Xexecution_array_inst/Xx_execution_unit/Xx_fft_16p/Xfft_16p_stage1_inst/Xfft_16p_mul1_inst/XU1302/MPA1_4  M(lvtpfet)
         g: X329/852                                               g: Xexecution_array_inst/Xx_execution_unit/Xx_fft_16p/Xfft_16p_stage1_inst/Xfft_16p_mul1_inst/n609
         ** VDD **                                                 b: VDD
发表于 2014-1-26 09:26:55 | 显示全部楼层
"MOS管的衬底没有直接连到VDD或VSS上,而是连到了一个二极管上"
就拿56那个error来说好了,
         ** VDD **                                                 b: VDD
在 Layout 上,substrate 是连到 X329/1929 这条 net (二极管的一端), 但是 netlist 上却是直接接到 VDD.
 楼主| 发表于 2014-1-26 10:37:01 | 显示全部楼层
对呀,我也看出来了,但是不知道为什么layout里面会有个二极管,而网表中却没有,是因为在ICC中用了什么器件单元吗?
 楼主| 发表于 2014-1-26 11:09:11 | 显示全部楼层
求助啊,没人解释一下吗
发表于 2014-1-26 16:48:04 | 显示全部楼层
Fram View 是你自己做的?
发表于 2014-1-26 16:51:04 | 显示全部楼层
衬底没加吧。版本上。b级都是一个非电源地线的节点了。
发表于 2014-1-26 16:53:25 | 显示全部楼层
这个样子还真不好看。
 楼主| 发表于 2014-1-26 18:11:23 | 显示全部楼层
不是自己做的,icc不出来的。
 楼主| 发表于 2014-1-26 18:16:16 | 显示全部楼层
衬底应该怎么加啊?网表里我是直接把VNW和VPW改成了了VDD和VSS上,但是layout里面b端都经过了一个二极管才连到电源和地上,不知道什么原因?
发表于 2014-1-27 10:27:14 | 显示全部楼层
std cell filler加了吗?
GMT+8, 2025-12-21 08:16 , Processed in 0.026960 second(s), 5 queries , Gzip On, Redis On.
