查看: 6466|回复: 2
[求助] UVM编译时报错
发表于 2014-1-24 10:39:10 | 显示全部楼层 |阅读模式
在顶层设计的时候,在initial块里面这样设计的:
initial
  begin
      uvm_config_db #(virtual bk_odua_pro_if)::set  (null,"uvm_test_top.env.i_agt.drv","bk_odua_pro_if",top_bkif); //odua_case0,odua_case1 instance name is uvm_test_top
      uvm_config_db #(virtual bk_odua_pro_if)::set(null,
     "uvm_test_top.env.o_agt.mon","bk_odua_pro_if",top_bkif); // odua_case0,odua_case1 instance name is uvm_test_top
       run_test("odua_case0");  // an UVM global function,begin to initiate UVM
  end
编译时报错:identifier 'run_test' has not been declared yet. If this error is not expected, please
                 check if you have set 'default_nettype' to none.
在平台设计中,并没有设置default_nettype为none。有知道的,请帮忙解答。
发表于 2014-1-24 12:08:19 | 显示全部楼层
没有把UVM的库导进去。。。
 楼主| 发表于 2014-1-24 15:42:56 | 显示全部楼层
回复 2# A1985
    嗯,是的,在顶层加一句 import uvm_pkg::*;  就ok了。
GMT+8, 2025-12-30 00:11 , Processed in 0.018804 second(s), 7 queries , Gzip On, Redis On.
