楼主 |
发表于 2013-12-21 16:26:40
显示全部楼层
好吧,之前的问题是因为sdf没标上。。。。但是标上以后出现了下面的问题:
SDF Info: +pulse_r/100, +pulse_e/100 in effect
Warning-[SDFCOM_IWSBA] INTERCONNECT will still be annotated
DSM_201302.SDF, 377
module: XOR2XL, "instance: testbench.dsm_201302_inst.add_38.U2"
SDF Warning: INTERCONNECT from add_38.U2.Y to
add_0_root_add_0_root_add_41_2.U36.B0 has Instance at DSM_201302_HIER.v:393,
delay will still be annotated.
Warning-[SDFCOM_UHICD] Up-hierarchy Interconnect Delay ignored
DSM_201302.SDF, 902
module: DFFSRHQX1, "instance: testbench.dsm_201302_inst.P_reg_0_"
SDF Warning: INTERCONNECT Delay to up-hierarchy destination accOutput is
ignored, DEVICE Delay on port 'Q' applied.
Up-hierarchy interconnect delay arises when the load is hierarchically above
the source.
DSM_201302.SDF, 903
module: DFFSRHQX1, "instance: testbench.dsm_201302_inst.P_reg_1_"
the source.
DSM_201302.SDF, 904
module: DFFSRHQX1, "instance: testbench.dsm_201302_inst.P_reg_2_"
the source.
DSM_201302.SDF, 905
module: DFFSRHQX1, "instance: testbench.dsm_201302_inst.P_reg_3_"
the source.
DSM_201302.SDF, 906
module: DFFSRHQX1, "instance: testbench.dsm_201302_inst.P_reg_4_"
the source.
DSM_201302.SDF, 907
module: DFFSRHQX1, "instance: testbench.dsm_201302_inst.P_reg_5_"
the source.
Warning-[SDFCOM_CFTC] Cannot find timing check
DSM_201302.SDF, 4836
module: DFFRXL, "instance: testbench.dsm_201302_inst.Out_offset_reg_0_"
SDF Warning: Cannot find timing check $recovery(posedge RN,posedge CK,...)
DSM_201302.SDF, 4858
module: DFFSRHQX1, "instance: testbench.dsm_201302_inst.K_out_reg_1_"
SDF Warning: Cannot find timing check $recovery(posedge SN,posedge CK,...)
All future warnings not reported; use +sdfverbose to report them.
DSM_201302.SDF, 4860
Total errors: 0
Total warnings: 105
*** SDF annotation completed: Sat Dec 21 15:23:05 2013
Starting vcs inline pass...
478 modules and 17 UDPs read.
However, due to incremental compilation, no re-compilation is necessary.
ld -r -m elf_i386 -o pre_vcsobj_1_1.o --whole-archive pre_vcsobj_1_1.a --no-whole-archive
ld -r -m elf_i386 -o pre_vcsobj_1_2.o --whole-archive pre_vcsobj_1_2.a --no-whole-archive
if [ -x ../simv ]; then chmod -x ../simv; fi
g++ -o ../simv -melf_i386 -Wl,-whole-archive -Wl,-no-whole-archive SIM_l.o 5NrI_d.o 5NrIB_d.o pre_vcsobj_1_1.o pre_vcsobj_1_2.o rmapats_mop.o rmapats.o /home/tian/programs/synopsys/vcs/linux/lib/libvirsim.so /home/tian/programs/synopsys/vcs/linux/lib/librterrorinf.so /home/tian/programs/synopsys/vcs/linux/lib/libsnpsmalloc.so /home/tian/programs/verdi/share/PLI/vcs/LINUX/pli.a /home/tian/programs/synopsys/vcs/linux/lib/libvcsnew.so /home/tian/programs/synopsys/vcs/linux/lib/libuclinative.so /home/tian/programs/synopsys/vcs/linux/lib/vcs_save_restore_new.o /home/tian/programs/synopsys/vcs/linux/lib/ctype-stubs_32.a -ldl -lm -lc -lpthread -ldl
../simv up to date
Chronologic VCS simulator copyright 1991-2011
Contains Synopsys proprietary information.
Compiler version E-2011.03; Runtime version E-2011.03; Dec 21 15:23 2013
Doing SDF annotation ...... Done
"csm18ic.v", 9109: Timing violation in testbench.dsm_201302_inst.K_out_reg_2_
$hold( posedge RN:882, posedge SN:1369, limit: 1000 );
"csm18ic.v", 9109: Timing violation in testbench.dsm_201302_inst.P_reg_2_
$hold( posedge RN:882, posedge SN:1370, limit: 1000 );
"csm18ic.v", 9109: Timing violation in testbench.dsm_201302_inst.P_reg_3_
$hold( posedge RN:885, posedge SN:1374, limit: 1000 );
"csm18ic.v", 9109: Timing violation in testbench.dsm_201302_inst.K_out_reg_3_
"csm18ic.v", 9109: Timing violation in testbench.dsm_201302_inst.K_out_reg_0_
$hold( posedge RN:777, posedge SN:1376, limit: 1000 );
"csm18ic.v", 9109: Timing violation in testbench.dsm_201302_inst.P_reg_0_
"csm18ic.v", 9109: Timing violation in testbench.dsm_201302_inst.K_out_reg_5_
$hold( posedge RN:885, posedge SN:1392, limit: 1000 );
"csm18ic.v", 9109: Timing violation in testbench.dsm_201302_inst.P_reg_5_
$hold( posedge RN:885, posedge SN:1393, limit: 1000 );
"csm18ic.v", 9109: Timing violation in testbench.dsm_201302_inst.P_reg_4_
$hold( posedge RN:901, posedge SN:1400, limit: 1000 );
"csm18ic.v", 9109: Timing violation in testbench.dsm_201302_inst.K_out_reg_4_
$hold( posedge RN:901, posedge SN:1401, limit: 1000 );
"csm18ic.v", 9109: Timing violation in testbench.dsm_201302_inst.K_out_reg_1_
$hold( posedge RN:880, posedge SN:1404, limit: 1000 );
"csm18ic.v", 9109: Timing violation in testbench.dsm_201302_inst.P_reg_1_
$hold( posedge RN:880, posedge SN:1406, limit: 1000 );
"csm18ic.v", 9110: Timing violation in testbench.dsm_201302_inst.K_out_reg_0_
$hold( posedge SN:80505, posedge RN:80777, limit: 1000 );
"csm18ic.v", 9110: Timing violation in testbench.dsm_201302_inst.P_reg_0_
"csm18ic.v", 9110: Timing violation in testbench.dsm_201302_inst.K_out_reg_1_
$hold( posedge SN:80539, posedge RN:80880, limit: 1000 );
"csm18ic.v", 9110: Timing violation in testbench.dsm_201302_inst.P_reg_1_
$hold( posedge SN:80541, posedge RN:80880, limit: 1000 );
"csm18ic.v", 9110: Timing violation in testbench.dsm_201302_inst.P_reg_2_
$hold( posedge SN:80495, posedge RN:80882, limit: 1000 );
"csm18ic.v", 9110: Timing violation in testbench.dsm_201302_inst.K_out_reg_2_
$hold( posedge SN:80494, posedge RN:80882, limit: 1000 );
"csm18ic.v", 9110: Timing violation in testbench.dsm_201302_inst.P_reg_3_
$hold( posedge SN:80471, posedge RN:80885, limit: 1000 );
"csm18ic.v", 9110: Timing violation in testbench.dsm_201302_inst.K_out_reg_3_
"csm18ic.v", 9110: Timing violation in testbench.dsm_201302_inst.P_reg_4_
$hold( posedge SN:80503, posedge RN:80901, limit: 1000 );
"csm18ic.v", 9110: Timing violation in testbench.dsm_201302_inst.K_out_reg_4_
$hold( posedge SN:80504, posedge RN:80901, limit: 1000 );
经检查,所有出现violation的均为output端口,不知道是不是因为有些delay没加进去引起的还是确实是约束有问题? |
