查看: 8107|回复: 21
[讨论] cadence ic610 and mmsim10 installation in RHEL6
发表于 2013-12-20 21:35:22 | 显示全部楼层 |阅读模式
any landlord please help me to install ic610 and mmsim10 in rhel 6
发表于 2013-12-20 23:48:07 | 显示全部楼层
www.ece.unm.edu/~jimp/vlsi_synthesis/cadence_install/InstallIC615.txt
 楼主| 发表于 2014-1-3 01:42:07 | 显示全部楼层
回复 2# mabas.masood
   landlord the given link is not open...please help me landlord to install ic610 and mmsim 10 in rhel 6
发表于 2014-1-3 05:30:51 | 显示全部楼层
you must install centos package (pkgs.org)
tcsh
ksh
after that you use this link
http://getglitched.com/?page_id=143
 楼主| 发表于 2014-1-6 20:21:10 | 显示全部楼层
回复 4# mabas.masood
is it possible to install ic610 in centos 6.2 please help me landlord to install ic610 and mmsim in centos 6.2
发表于 2014-1-6 21:13:46 | 显示全部楼层
yes use can
please follow above link for install
 楼主| 发表于 2014-1-7 01:03:14 | 显示全部楼层
回复 6# mabas.masood Respected sir
i have installed centos 6.2 in my laptop but i was unable to connect in wifi connection can you please help me to enable wifi
发表于 2014-1-7 03:16:44 | 显示全部楼层
回复 7# sennajar
please  follow this link
http://wiki.centos.org/HowTos/Laptops/Wireless
after you find suitable driver search in pkgs.org
for example ipw2100-firmware is suitable for Intel Pro Wireless 2100 (ipw2100)
发表于 2014-1-21 23:27:21 | 显示全部楼层
i need it too
 楼主| 发表于 2014-2-3 02:20:53 | 显示全部楼层
回复 2# mabas.masood
respected sir,i have installed ic610 and mmsim61 assura41 in RHEL 4. in cadence schematic and simulation is working fine but when i use layout L to create layout in menu assura is not appearing ..kindly help me to solve this...i have attache the error window with this message.
assura menu not appear in virtuoso layout
GMT+8, 2025-12-23 02:34 , Processed in 0.024538 second(s), 6 queries , Gzip On, Redis On.
