楼主: sennajar
[讨论] cadence ic610 and mmsim10 installation in RHEL6
发表于 2014-2-3 05:07:04 | 显示全部楼层
go to assura/tools/lib and rename libstdc++.so.6 to libstdc++.so.6.back
after that copy libstdc++.so.6 and libstdc++.so.6.x.x from /user/lib to assura/tools/lib
发表于 2014-2-7 10:23:43 | 显示全部楼层
i need it
 楼主| 发表于 2014-2-8 21:18:05 | 显示全部楼层
回复 11# mabas.masood
i renamed the file and copied files from /usr/lib to assura/tools/lib folder but still the assura is available in virtuoso menu..please help me to solve this one...
发表于 2014-2-9 02:50:48 | 显示全部楼层
回复 13# sennajar
1- you must add this line in bashrc
export ASSURAHOME=/opt/cadence/ASSURA41
    export PATH=$ASSURAHOME/binPATH
2- probably your installed assura isn't correct version for ic610
 楼主| 发表于 2014-2-15 02:49:17 | 显示全部楼层
回复 14# mabas.masood
    Respected Sir i installed IC610 and MMsim6 in centOS6.2 and i assigned .bashrc as per in getclitched tutorial page
but the problem is when i run virtuoso it shows error like license file not found please help me to solve this
发表于 2014-2-15 09:45:29 | 显示全部楼层
回复 15# sennajar
    please send me several picture from:
1- terminal after run virtuoso that it shows error
2- .bashrc file
3- cadence ic6, mmsim and assura folders
 楼主| 发表于 2014-2-15 12:45:58 | 显示全部楼层
回复 16# mabas.masood
   Respected sir send me your mail id i ll send the snapshot images to your mail idthanks in advance
senthil rajan
发表于 2014-2-15 13:04:55 | 显示全部楼层
回复 15# sennajar
    mabas.masood@gmail.com
发表于 2014-5-21 22:09:58 | 显示全部楼层
多谢分享,谢谢
发表于 2014-5-21 22:17:30 | 显示全部楼层
多谢分享,谢谢
GMT+8, 2025-12-15 00:16 , Processed in 0.022591 second(s), 3 queries , Gzip On, Redis On.
