查看: 2596|回复: 6
[求助] 哪有IEEE数据库,帮我下载下列论文?谢谢
发表于 2013-12-10 16:00:40 | 显示全部楼层 |阅读模式
你好:
  能帮我下载下列论文吗?我们学校没有IEEE数据库,谢谢了!EMIAL:190126760@qq.com                                                          1)        An analysis of small-signal and large-signal base resistances for submicrometer BJT's
2)        Improved small-signal equivalent circuit model andlarge-signal state equations for the MOSFET/MODFET wave equation
3)        Consistent small-signal and large-signal extraction techniques for heterojunction FET's
4)        A new SPICE-type heterojunction bipolar transistor model for DC, microwave small-signal and large-signal circuit simulation
5)        Improving large signal analysis in DC/DC converters with a modified small signal model
6)        Small signal and large signal charge control models for a phase-shifted PWM converter
7)        Small signal and large signal modeling of HBT's using neural networks
8)        Small-Signal and Large-Signal Analysis of the Two-Transformer Asymmetrical Half-Bridge Converter Operating in Continuous Conduction Mode
9)        Large signal and small signal modeling techniques for AC-AC power converters
10)        Small-Signal Capacitance and Current Parameter Modeling in Large-Scale High-Frequency Graphene Field-Effect Transistors
11)        Small-Signal Capacitance and Current Parameter Modeling in Large-Scale High-Frequency Graphene Field-Effect Transistors
12)        High-frequency small-signal and large-signalcharacteristics of resonant tunneling high electron mobility transistors (RTHEMTs)
13)        A Unified Nonquasi-Static MOSFET Model for Large-Signal and Small-Signal Simulations
14)        A small-signal analytical theory for GaAs field-effect transistors at large drain voltages
15)        A large-signal SOI MOSFET model including dynamic self-heating based on small-signal model parameters
发表于 2013-12-10 22:11:15 | 显示全部楼层
哇哦。。有好心人帮你下载吗? 这么浪费时间的工作有好处么?
发表于 2013-12-11 10:02:23 | 显示全部楼层
10和11重复了,已发邮箱,其他人如果有需要可以联系LZ。
发表于 2013-12-11 11:21:27 | 显示全部楼层
3楼的真是好人,顶一个!
发表于 2013-12-11 14:42:08 | 显示全部楼层
三楼确实是好人,但是LZ你们学校没有IEEE数据库这也太搓了吧?
 楼主| 发表于 2013-12-12 10:30:38 | 显示全部楼层
回复 3# vvb6
   谢谢你,真的非常感谢你!
发表于 2013-12-12 14:45:11 | 显示全部楼层
回复 3# vvb6
   好人,略微表扬一下,以示敬意。
GMT+8, 2025-12-18 06:24 , Processed in 0.023019 second(s), 4 queries , Gzip On, Redis On.
