查看: 2031|回复: 0
[求助] pre-dft时,test332 warning 怎么解决??
发表于 2013-12-7 17:25:02 | 显示全部楼层 |阅读模式
The specified pin has no driver. This problem was previously reported as
warnings LINT-0 or LINT-3, if you have run ’check_design’. Note however that
for the purpose of test generation, pins that are not properly driven are
unknown. So, contrary to what was reported by check_design, DFT Compiler makes
no assumption about the missing connection.
GMT+8, 2025-10-8 18:21 , Processed in 0.012845 second(s), 5 queries , Gzip On, Redis On.
