查看: 8113|回复: 21
[其它] 注入区做大一些有什么用?
发表于 2013-11-12 16:18:28 | 显示全部楼层 |阅读模式
悬赏14资产已解决
最佳答案
查看完整内容
the injection region is supposed to be active region (AA)? for mosfet 1, the active region defines the channel weight, so the poly gate should have some extension from the edge of active region. for mosfet 2, I see no point to draw the layout like this. the poly gate connection is inside the active region, and you don't know how much it is the channel length, and the current distribution from dr ...
发表于 2013-11-12 16:18:29 | 显示全部楼层
for mosfet 2, I see no point to draw the layout like this. the poly gate connection is inside the active region, and you don't know how much it is the channel length, and the current distribution from drain to source is not uniform.
 楼主| 发表于 2013-11-12 21:24:36 | 显示全部楼层
发表于 2013-11-13 09:32:57 | 显示全部楼层
回复 3# istart_2002
    OK , i see , then no problem for the mosfet2.
if both the style meet the DRC rules, little difference should happen in simulation.
anyway, larger injection region usually means larger device area if keep others dimensions unchanged.
发表于 2013-11-13 11:17:55 | 显示全部楼层
I agree.
There is no difference between MOS1 and MOS2.
Only the region (Active 'AND' Implant) will be doped.
Minor difference: MOS2 will have more doping on gate. It will change the gate resistance a little.
 楼主| 发表于 2013-11-13 11:29:43 | 显示全部楼层
回复  istart_2002
if both the style meet  ...
wfcawy 发表于 2013-11-13 09:32
   在库里是两种不同的器件,没区别为什么要做成两种器件~~~~
 楼主| 发表于 2013-11-13 11:30:18 | 显示全部楼层
I agree.
Only the region (Active 'AND' Implant) will ...
发表于 2013-11-13 11:34:41 | 显示全部楼层
具体哪个工艺?
是不是还有其他区别?
 楼主| 发表于 2013-11-13 11:45:49 | 显示全部楼层
.35bicmos 从版图来看,就是这个区别~
发表于 2013-11-13 22:05:28 | 显示全部楼层
回复 7# istart_2002
    please provide more information on your  library PDK related to the two device.
GMT+8, 2025-9-15 08:07 , Processed in 0.021234 second(s), 5 queries , Gzip On, Redis On.
