查看: 6416|回复: 5
[求助] Random Sequence Generation问题,编译有点问题,望大家帮忙看看
发表于 2013-9-26 14:07:07 | 显示全部楼层 |阅读模式
我在学习Random Sequence Generation时,编译有点问题,不知什么原因?望大家帮忙看看,多谢!
我把书上的代码编译了下,有错误。代码如下:
  1. program p;
  2. initial begin
  3. randsequence()
  4. main : repeat (10) TOP;
  5. TOP: RJ {$display("");};
  6. RJ: rand join (1.0) S1 S2 S3;
  7. S1 : A B;
  8. S2 : C D;
  9. S3 : E F G;
  10. A : {$write ("A");};
  11. B : {$write ("B");};
  12. C : {$write ("C");};
  13. D : {$write ("D");};
  14. E : {$write ("E");};
  15. F : {$write ("F");};
  16. G : {$write ("G");};
  17. endsequence
  18. end
  19. endprogram
    复制代码
编译错误如下:
  1. irun: 10.20-s100: (c) Copyright 1995-2011 Cadence Design Systems, Inc.
  2. TOOL:        irun        10.20-s100: Started on Sep 26, 2013 at 12:47:57 CST
  3. irun
  4.         -sv
  5.         -seed random
  6.         RSG.sv
  7. Recompiling... reason: file './RSG.sv' is newer than expected.
  8.         expected: Thu Sep 26 12:36:35 2013
  9.         actual:   Thu Sep 26 12:47:56 2013
  10. file: RSG.sv
  11.             RJ : rand join (1.0) S1 S2 S3
  12.                     |
  13. ncvlog: *E,RSNOPROD (RSG.sv,6|20): randsequence production has no production items [SystemVerilog LRM, randsequence].
  14.             RJ : rand join (1.0) S1 S2 S3
  15.                     |
  16. ncvlog: *E,RSSEMICLN (RSG.sv,6|20): Expected semicolon after a randsequence production [SystemVerilog LRM, randsequence].
  17.             RJ : rand join (1.0) S1 S2 S3
  18.                          |
  19. ncvlog: *E,RSENDSEQ (RSG.sv,6|25): randsequence must end with "endsequence".
  20.             RJ : rand join (1.0) S1 S2 S3
  21.                            |
  22. ncvlog: *E,NOTSTT (RSG.sv,6|27): expecting a statement [9(IEEE)].
  23.             RJ : rand join (1.0) S1 S2 S3
  24.                                      |
  25. ncvlog: *E,MISEXX (RSG.sv,6|37): expecting an '=' or '<=' sign in an assignment [9.2(IEEE)].
  26.             RJ : rand join (1.0) S1 S2 S3
  27.                                         |
  28. ncvlog: *E,MISEXX (RSG.sv,6|40): expecting an '=' or '<=' sign in an assignment [9.2(IEEE)].
  29.             S1 : A B;
  30.              |
  31. ncvlog: *E,MISEXX (RSG.sv,7|13): expecting an '=' or '<=' sign in an assignment [9.2(IEEE)].
  32.             S1 : A B;
  33.              |
  34. ncvlog: *E,NOLABL (RSG.sv,7|13): Labels are not supported on this statement type.
  35.             S1 : A B;
  36.                    |
  37. ncvlog: *E,MISEXX (RSG.sv,7|19): expecting an '=' or '<=' sign in an assignment [9.2(IEEE)].
  38.             S2 : C D;
  39.
    复制代码
发表于 2013-9-27 11:22:37 | 显示全部楼层
使用vcs2012.09和ius12.20都可以编译通过并仿真。
不过还是有个针对rand join (1.0) ... 中的1.0的warning,没用过这个,不太清楚为什么还有wanrning。
 楼主| 发表于 2013-9-27 15:06:20 | 显示全部楼层
回复 2# remnant
   莫非是版本问题,我用的是irun 2011跑的,会不会是版本不支持呢?
发表于 2013-9-27 16:59:32 | 显示全部楼层
    有这个可能性。仿真器版本不同,对systemverilog标准实现的程度是不一样的。
    另外,你用的不叫irun 2011,而是ius10.20。
 楼主| 发表于 2013-9-28 09:12:01 | 显示全部楼层
回复 4# remnant
   哦,多谢!
 楼主| 发表于 2013-9-28 09:13:33 | 显示全部楼层
回复 4# remnant
   哦,感谢,的确是ius10.20-s100
GMT+8, 2025-12-18 06:32 , Processed in 0.014660 second(s), 3 queries , Gzip On, Redis On.
