查看: 7975|回复: 3
[求助] 请教各位大大。。redhawk|APL-DD mode 该如何启动
发表于 2013-7-16 16:53:29 | 显示全部楼层 |阅读模式
For design-specific characterization:
1. Prepare the GSR file for running RedHawk. Refer to Appendix C,  “File Definitions”.
2. Select the GUI command APL -> Setup in RedHawk, or use the TCL command
                         setup apl -dir <dir_name>
This generates two intermediate files required for APL characterization, apache.apl
and  adsLib.output, and places them in the <dir_name>/.apache directory.
In addition, four types of APL configur ation file templates are created in the
specified <dir_name> directory, to assist in preparing the proper configuration files
for characterization:
&#8226; apl.custom.config
&#8226;apl.io.config
&#8226;apl.memory.config
&#8226; apl.std.config
Cell list files for all four types of  cells are also placed in the  <dir_name> directory.
3. Prepare the APL configuration file defining characterization conditions desired, as
described previously in section "APL Configuration File Description", page 9-229.
4. Run APL-DD to obtain switching current profiles, device capacitance and
resistance for cell high and low states, and leakage current for all design cells.
最后一步:RUN apl-dd ,使用apl----》character可以么?
请指教,apl-dd mode下的config与flow跟apl-di模式下的config与flow之间的差异。
发表于 2015-11-12 17:00:50 | 显示全部楼层
你用的盗版么?
发表于 2016-6-13 12:12:32 | 显示全部楼层
thanks
发表于 2018-4-12 14:55:20 | 显示全部楼层
goodd
GMT+8, 2025-12-13 19:07 , Processed in 0.018514 second(s), 5 queries , Gzip On, Redis On.
