查看: 1577|回复: 1
[求助] ICC中define routing rule处理双倍线宽所报出的warning
发表于 2013-7-11 10:54:56 | 显示全部楼层 |阅读模式
在define_routing_rule MY_ROUTE_RULES -widths {METAL3 0.56} -spacings {METAL3 0.58}当我做完这个设定以后报出了一下的warning:
Warning:The 'via2v' via enclosure width is less than NDR width constraint of  'METAL3 Layer'
Warning:The 'via3h' via enclosure width is less than NDR width constraint of  'METAL3 Layer‘
Warning:The 'via3h' via enclosure width is less than NDR width constraint of  'METAL4 Layer’
对于这样的warning是否可以忽略呢?
谢谢啦
发表于 2013-7-12 09:56:51 | 显示全部楼层
帮顶的~~~谢谢了
GMT+8, 2025-10-31 21:06 , Processed in 0.014194 second(s), 5 queries , Gzip On, Redis On.
