查看: 2212|回复: 3
[求助] ICC中define routing rule处理双倍线宽所报出的warning
发表于 2013-7-11 10:54:54 | 显示全部楼层 |阅读模式
在define_routing_rule MY_ROUTE_RULES -widths {METAL3 0.56} -spacings {METAL3 0.58}当我做完这个设定以后报出了一下的warning:
Warning:The 'via2v' via enclosure width is less than NDR width constraint of  'METAL3 Layer'
Warning:The 'via3h' via enclosure width is less than NDR width constraint of  'METAL3 Layer‘
Warning:The 'via3h' via enclosure width is less than NDR width constraint of  'METAL4 Layer’
对于这样的warning是否可以忽略呢?
谢谢啦
发表于 2013-7-12 09:48:51 | 显示全部楼层
纯粹帮顶的
··1
发表于 2013-7-14 23:28:28 | 显示全部楼层
当然可以,谢谢。
发表于 2013-7-14 23:29:12 | 显示全部楼层
当然可以,谢谢
GMT+8, 2025-8-25 07:31 , Processed in 0.012992 second(s), 3 queries , Gzip On, Redis On.
