查看: 6387|回复: 0
[招聘] 【社会招聘】LSI 2013年6月中国热招职位
发表于 2013-6-7 13:31:30 | 显示全部楼层 |阅读模式
请将简历发至:
Tracey.zheng@lsi.com
如有任何疑问,请发送邮件至Tracey.zheng@lsi.com或拨打电话021-24191709.
也可加我msn: zql975504@hotmail.com
或微博:
http://www.weibo.com/u/1752448637
QQ: 2306464914
LSI中国在20132014还会处于快速的成长阶段,如果您目前在下面没有找到合适的职位,也欢迎联系,我们随时都可能有适合你职业发展的机会呦!
Job Title:
HDD Read Channel Architect
Job Description
- We are looking for an engineer with a track record of excellent performance to join our read channel architecture team. In this role you would be part of a dedicated team developing LSI's leading hard disk drive ASIC technology.
- This job spans the invention process from the conception of a new idea, through reduction to practice in software, close collaboration with design teams and verification of the design through to validation of performance through bench testing. In your role you will with work closely with Design and Verification teams in Shanghai and with the RC Architecture team in the United States.
- Our core requirements are a deep knowledge of digital communications technology; familiarity with detection and coding for magnetic recording; some experience implementing signal processing and detection algorithms in software and good programming skills in C/C++ and scripting languages. Experience with design verification and bench testing would both be very desirable.
Requirements/Qualifications (Education)
- PhD/Master in Electrical Engineering or equivalent. Deep knowledge of the principles of digital communications. Familiarity with signal processing and programming
Job Title: Firmware Engineer -Shanghai
Job Description
- Must demonstrate expertise in design and implementation of event-driven, real time firmware solutions using C/C++ programming
- Must be able to work with ASIC and software engineers in a collaborative environment
- Quick learner with high level of self-motivation and dedication, with ability to deliver high quality products on time
- Must have an excellent computer science background and demonstrated strength in designing efficient embedded firmware for storage or networking products
- Firmware/System debug skills utilizing debugger, protocol analyzer is required
- Good understanding of RTOS concepts including task switching, deadlocks, and resource management issues is required
- High level of skill in problem recreation, trapping and resolution, possess good written and verbal communication skills.
- Communicate effectively in a team, able to multitask effectively in fast-paced environment.
- Understanding of NAND Flash concepts, knowledge of Flash management techniques, including wear leveling, garbage collection (optional but strong plus).
- Knowledge and hands-on experience with storage protocols is preferred (SAS / SATA)
- Experience with Multi-Core design such as ARM or Tensilica cores is preferred.
- BS in Electrical Engineering, Computer Science, or Computer Engineering is required with 6+ years of firmware development
- M.S. preferred with 4+ years in firmware development
Job Title: Software Quality Assurance (SQA) Validation Architecture-Shanghai
Job Description:
During project startup, analyze customer and firmware requirement, design overall validation architecture and test flow based on the requirement and design document.
Lead the test development and system validation of significant functional blocks, ensuring minimal test escapes after qualification
Develop and enhance automation infrastructure to support regression tests. (Not must, but a strong plus)
Be responsible for firmware functionality, performance, stress, reliability tests.
Define systematic test flow, collect and analyze test result, implement test automation, increase test efficiency and quality.
Work with team members to design, execute, and optimize test flow, improve test coverage.
Work closely with cross functional teams to ensure projects running smoothly; provide suggestions to improve firmware quality.
Requirements/Qualifications (Education):
BS and above. in Electrical Engineering, Computer Science, or Computer Engineering.
At least 8 years’ experience in software/firmware quality assurance development, including 4 years in storage industry.
Extensive knowledge of software/firmware testing and quality methods.
Communicate effectively in a team, patient and careful, able to multitask effectively in fast-paced and stressed environment
Prior experience in technical leader role, hands on experience in driving quality improvement programs is preferred.
Understanding of NAND Flash concepts, knowledge of Flash management techniques, including wear leveling, garbage collection (strong plus)
Job Title: Software Quality Assurance (SQA) Engineer-Shanghai
Job Description:
Analyze firmware requirement, compose test plan, design document, write test case.
Implement test cases in script language.
Collect and analyze test result, track issues reported closely.
Implement test automation, increase test efficiency and quality.
- BS in Electrical Engineering, Computer Science, or Computer Engineering, with at least 3 years’ experience in software/firmware testing.
- MS. with at least 2 years’ experience in software/firmware testing.
- Extensive knowledge of software/firmware testing and quality methods.
- Experience with shell/script language is a must.
- Communicate effectively in a team, patient and careful, able to multitask effectively in fast-paced and stressed environment.
- Relative experience in storage industry is strongly preferred.
- Understanding of NAND Flash concepts, knowledge of Flash management techniques, including wear leveling, garbage collection (strong plus)
Job Title: Read Channel Verification Engineer-Shanghai
Job Description:
As a member of the Read Channel team, candidate must be willing to work as an extended member of the design team. Duties will include functional verification of Storage read channel mixed-signal IP. Candidate will be expected to contribute to design and development of System Verilog based verification environment and will be responsible for verification closure of block/chip/system level functions for mixed signal based IP. Experience with System Verilog and functional coverage methodologies are required. Must be willing to follow a disciplined verification methodology and to work closely with a multi-location, international design team. Excellent teamwork and communication skills are required.
Requirements/Qualifications (Education) :
BSEE with 3-5+ years of design and/or verification experience required, MSEE preferred.
Required knowledge and skills:
- Expertise in System Verilog required
- Good understanding of Digital Signal Processing
- Good understanding of Analog and Digital Circuits
- Very good analytical/debugging skill
- Good verbal and written communication skills
Desirable skills:
- Knowledge of Verilog-AMS, Perl
- Knowledge of verification methodologies including functional coverage and constrained
random testing
- Knowledge of VLSI design flows & DFT
- Familiarity of high level programming language
- Experience working with globally distributed team
Job Title: Preamp Verification Engineer -Shanghai
Job Description:
LSI's Storage Peripherals Division is seeking an experienced verification design engineer to join the pre-amplifier design team. Preamp design team members define, create, modify and verify high-speed custom integrated circuits for hard disk drive (HDD) and tape recording products using leading edge CMOS and BiCMOS technologies
- Work with a Preamp Development team to create verilog testbench components and simulation environment.
- Create product test plans, test cases and perform simulation and debug of Storage Preamp mixed-signal devices.
- Must be experienced with Verilog and Verilog AMS and knowledgeable with functional coverage methodologies.
- Ability to follow a disciplined verification methodology and work closely with a multi-location, international design team.
- Excellent teamwork and communication skills are required.
- Preferred degree in Electrical or Electronic Engineering.
- BS required, MS or Ph.D. preferred
- The ideal candidate will have 5 years of experience as a member of a Design Verification team
- Experience with successful tapeout of SoC products from verification plan to sign-off including verification plan, reusable test bench development, random-constrained test case creation, RTL/Gate level simulation/debug, code/functional coverage analysis and regression
- Conversant with Verilog, SystemVerilog, Specman, Perl/Python/Tcl scripts, Makefile and EDA tools
- Experience with Assertion or Formal Verification a plus
- Strong communication skills (must be proficient in both spoken and written English)
- Able to travel internationally (to United States and throughout Asia
- Understanding of silicon process technologies (CMOS and Bipolar) and device physics would be a plus.
- Conversant with Verilog-AMS/Verilog-A and Analog Behavior Modeling would be a plus
- Proven analytical skills (application of math and physics to solve problems)
Job Title:
Preamp Analog/Mixed Signal Design Engineer-Shanghai
Job Description:
- Design high speed analog and mixed-signal integrated circuits within custom chips for the hard disk drive industry
- Work directly with customers to determine system requirements, write specifications and guide customers in the use of pre-amplifier products
- Use high speed electronic characterization equipment to evaluate and debug the functionality of the design once the part is fabricated in silicon
- Provide technical leadership through all phases of product development including test, yield, characterization, reliability analysis, qualification and release to manufacturing
LSI's Storage Peripherals Group is looking for an experienced custom analog IC designer to join the pre-amplifier design team. At LSI we are committed to innovation and industry leadership. We develop advanced high-speed magneto electronic read/write IC architectures as the basis for our products.
Design team members define, create and modify high-speed custom integrated circuits for hard disk drive (HDD) products using leading edge CMOS and SiGe BiCMOS technologies.
Team members support the entire product life cycle beginning with design and moving through test, qualification, release to production and ramp to volume.
- Degree in Electrical Engineering (or related field), MS required, Ph.D. preferred
- 5 years and above Experience with analog and mixed signal IC product design, integration and verification is required.
- Strong physical layout knowledge and parasitic component understanding essential
- Process and device physics knowledge critical
- Proven skills using electronic measurement equipment in a lab environment
- Expertise in applied magnetism and recording a strong plus
Job Title:
NPI Program Manager –Shanghai
Job Description
Scope of programs: - Geographic spread across US & Asia - Mission critical SoCs with enormous business impact in the $100M+ range - High development cost and effort and significant cross-functional coordination & teamwork Responsibilities: - Project Definition: * Support quote & SOW/PRD generation as needed * Support design managers & program managers in defining baseline plan of record or POR (scope, schedule, resources/budget, quality, etc.) for the program * Develop project plans & risk mitigation plans for new product introduction (NPI) including wafer fabrication, assembly, test, proto ship, validation, qualification and production ramp * Coordinate and facilitate the set up of program teams in cooperation with other functional groups * Drive project plans for product cost reduction and second sourcing initiatives across multiple products - Project Execution: * Setup & moderate regular program review meetings, internal and, if needed, with the customer across time zones * Provide leadership role to cross-functional teams and manage internal and customer interactions as needed * Be an interface to key customer contacts involved in new product introduction & product ramp * Be the main interface to other groups within the company – especially design/product eng/test eng/operations/supply chain etc.; establish and maintain effective communication management * Drive effective communication to senior management on project status and metrics * Drive common stage gate process as well as quality/milestone checklists to enable superior product delivery planning & execution * Drive implementation & adoption of key program management methodologies and tools * Maintain and measure project progress against plan * Support ongoing risk/issue management * Facilitate Project Lessons Learned (internal and with the customer) * Drive continuous improvement in product delivery through collaboration * Train program managers located at other geographic sites (e.g., Asia) * Identify ways to drive major improvements in product delivery TAT, product quality and product cost - General Program management: * Partner with various organizations to drive efficient & common program management practices & capabilities * Drive the development and adoption of common NPI milestones, checklists and handoff requirements * Support PMO in monthly or quarterly program reviews * Become a PMO advocate and expert * Drive the management of product issues in NPI to ensure quick corrective and preventive action implementation
Job Title: Product Engineering Manager -Shanghai
Job Description:
Product Engineering Manager. Hand-on experienced leader to drive improved performance and execution across all LSI silicon products. Willing to work with extended international teams across multiple time-zones and business units supporting product design, marketing, sales, operations, quality and finance through interactions during product development and high volume manufacturing. Good English skills are required. A BS in EE is preferred with at least 5 years of hands on product engineering experience. A background in silicon wafer process or test development is also a bonus. Must also have the ability to bring junior engineers up to speed in addition to having the capability to independently make decisions at a high level. This role will work closely with test engineering, silicon design and validation teams, program management – in addition to direct customer interfacing for China/APAC based customers. Familiarity with standard product development cycle support needs and a laser focus on cost, quality and manufacturing robustness is a big plus
A BS in EE is preferred with at least 5 years of hands on product engineering experience. Good English skills a required. A background in silicon wafer process or test development is also a bonus
Job Title: Product Engineer -Shanghai
Description:
Product Engineer will be the product owner, responsible from new product introduction to end of life for factors ranging from yield, performance, quality and cost.  Background in ATE, foundry or design/validation would be a big plus, since the product engineer would work with these teams over the lifetime of the product.  Experience with customer friendly communications is not required, but would be a bonus, since a good portion of the job responsibility will also revolve around technical communications with various end customers.
Requirements:
BS in Electrical Engineering (or Engineering with an emphasis on electronics/electronic materials), 2-5 years’ experience in a fabless semiconductor company supporting internal design teams and external customers a plus.  Flexibility and willingness to work with remote (US/India) based teams a must.  Good English communications capability is also needed.
Job Title: Test Operation Engineer-Shanghai
Job Descriptions:
To support new product introduction into subcontractors and facilitate high volume ramp
- Manage execution deliverables covering test programs and all the essential test hardware and co-work with supply chain management to meet/exceed on time deployment at subcontractors
- Drive KPIs at subcontractors to meet/exceed LSI performance metrics expectations
- Drive cost reduction and margin improvement initiatives to achieve the manufacturing cost objectives
- Support new technology/best practices evaluation/assessment, early adoption and introduction into subcontractors
- Ensure test process compliance to prevent manufacturing execursions
- Ensure compliance of quality requirements at subcontractors
Requirements:
- University graduate (EE degree) with 5 years or more in product, test, and high volume manufacturing operations experiences in the semiconductor area
- Solid background in high speed digital and mixed-signal testing is essential
- Working experiences with ATE andancillary test equipments. Teradyne Catalyst/UltraFlex, Advantest T2000, Delta/Seiko Epson handlers and TEL/Accretech/Opus probers will be of advantage
- C++ and/or Perl programming skills
Job Title: Test Engineer -Shanghai
Job Description:
- To support prototype and production releases of new products. Manage debug of test program, design and debug of test hardware, and meet product release schedule
- Support test program development for implementing changes in new test methodologies for test coverage improvement
- Pursue Design for Test initiatives to optimize testability and achieve test cost reduction via test time reduction and multiple site test solutions for production release
- Support test chip test development and characterization of new IP used in LSI products
- University graduate students with top scores in GPA
- Prior working experiences in the semiconductor industry field, specially in either IDM, Fabless, or ATE vendor background
- ATE programming skills would be essential. T2000, U-flex platform knowledge is preferred
- VB, VC and/or Perl programming skills JD
Job Title: WebCloud Account Sales-Shanghai
Job Description:
- This Account manager role is responsible for LSI’s storage business (ASD/RSD) for tier-1 WebCloud customers in North or East China region. It required knowledge and expertise in SSD/Flash, SAS/SATA, RAID, x86 Server, storage, database, distributed application areas for selling LSI’s Flash and SAS storage solution to those tier-1 WebCloud customers like Tencent, Alibaba and Baidu. This role also required strong background and understanding in MDC (Mega Data center) server storage architecture, the key needs and trends in storage area for MDC, and also how to apply flash technologies into MDC to accelerate the storage performance. For all assigned customers and projects, this role is responsible for identifying new business opportunity, arrange the pre-sale supports, close the design win, drive the customer satisfactory, manage the customer relationship and eventually drive and grow the overall LSI sales revenue from the account. This role also needs to define sales plan, provide regular business updates/design win updates and revenue forecast, work with LSI product team and all functional team, to take the lead and be accountable in archiving design win target and sale revenue quota. This role required strong English communication capability, in both written and speak, to support the daily work with support team and product team. Other than to drive the direct sale with tier-1 WebCloud customers, this account manager role also need to build up the relationship and engagement model, to influence customer’s preference in storage technologies, partner with LSI’s OEMs to grow the business size, identify new business opportunity for LSI’s Flash/SAS storage solution
- Strong background and understanding in WebCloud customers
- 7+ years working experience in IT server storage industry
- 3+ years working experience in global company
- Strong understanding in Flash storage solution and the industry trends
- Strong English communication both in written and in verbal
- Self motivated person with passion for success
- Strong leadership skill to drive both internal and external to make things happen
- Bachelor in Computer Science or EE
Job Title: Customer Firmware Application Engineer –Shanghai
Job Descriptions:
- Provide Tier 1 customer firmware support.
- Act as firmware technical lead within the application engineering organization.
- Manage and prioritize customer issues and customer expectations releasing firmware updates back to customers.
- Train and teach internal application engineers on firmware implementation and architecture.
- Minimal travel required.
- BS EE or CS required, MS preferred
- Must have experience with C/C++
- Min 7+ years of firmware experience
- Create and propose product concepts to executive level staff
- Excellent verbal and written communication skills. High technical comprehension a must . Must be able to translate complex ideas into easily communicated messages
- Experienced with High Speed I/O interfaces from physical to protocol level (SAS, SATA, InfiniBand, FC, Ethernet, PCI Express), Memory technology (SRAM, DRAM, Flash, etc). Must have familiarity with Server
and Storage system architecture
Job Description
Job Title: Field Application Engineer-Shanghai/Beijing
Job Descriptions:
Work closely with Sales and customers to provide excellent support of new and existing business, including pre-design win and post design win.
Achieve design wins at customers
Support customers on-site when needed.
Work closely with global technical colleagues (USA, China) to provide backup support.
Track issues and defects and drive to resolution.
Provide quick response to key customer’s request on technical support.
Provide technical training to Sales team and customers.
Job Requirements:
- 3 years+ of experience with Storage controller, Storage system and/or flash solution.
-Knowledge and experience in Firmware/Software, SAS server system, flash solution and datacenter. Oracle Database knowledge or PCIe based flash card/flash solution is a plus.
- Experience supporting storage products eg. SAS processor/Controller/Expander or storage system or webcloud customers
- Broad Network or Storage knowledge
- Demonstrated ability to learn technology quickly
- Very good English communication skills
- Team player, self-motivation
- Communication/Information Systems or EE degree, Masters preferred
- Bachelors in Computer Science or equivalent experience required. Higher Degree preferred.
Job Title: System Administrator -Contractor
Job Description
- 3-5 years of experience with Unix and/or Linux (Solaris and RedHat Linux OS) administration.
- 1-3 years of experience with Storage and Backup infrastructure administration with experience in Network Appliance Filers, SAN, OnStor gateways, EMC, Veritas Cluster Software, Veritas File System, Volume Manager, enterprise RAID Array and Netbackup.
- 1-2 years of practice with lab management including various deploys about server, desktop, laptop and network.
- Vendor relation management experience required. Ability to work with a flexible schedule.
- Skilled with Perl/Python, Bash/Tcsh and other Scripting languages
- Ability to work in a fast-paced engineering environment with a positive customer service and teamwork attitude.
- Familiarity with Semiconductor and Design Center business operation.
- Demonstrates initiative & contributes to problem solving.
- Good knowledge of TCP/IP networking,
- Excellent written and verbal communication in English
GMT+8, 2025-12-21 03:56 , Processed in 0.024104 second(s), 6 queries , Gzip On, Redis On.
