查看: 3198|回复: 2
[求助] Questions related to STIL DFT protocol file[DFT&TetraMax]
发表于 2013-4-25 16:46:11 | 显示全部楼层 |阅读模式
I met a problem about writing a spf.
1. During the initial stage, the test clock pin is required to set at 1'b1 for serving as a control signal (like reset), and then become to 1'b0 after a period of 5000ns.
2. After the reset is done, the test mode can only be triggered by a sequence of control inputs. And then the clock can be pulsed to start the scanning.
I tried to use V { "clk" = 1} in "test_setup" section to force the clk is in high state during the beginning. But the tetramax complains errors that "clk" should be pulsed, not forced on.
How can I write such spf for tetramax?
Thx a lot.
发表于 2013-5-4 09:06:55 | 显示全部楼层
顶顶更健康
发表于 2013-5-17 22:51:38 | 显示全部楼层
怎么样了?是不是可以这样,定义一个1在clk的wft中,你可以试试
GMT+8, 2025-9-14 04:49 , Processed in 0.016007 second(s), 5 queries , Gzip On, Redis On.
