查看: 2849|回复: 0
[原创] xilinx “out”偏移约束
发表于 2013-1-9 18:01:10 | 显示全部楼层 |阅读模式
现在在做输出偏移约束感觉比较奇怪的问题就是在约束一组八位数据的输出时有几位的结果差异很大具体如下:
Paths for end point dout<2> (W20.PAD), 1 path  --------------------------------------------------------------------------------  Slack (slowest paths):   -3.279 ns (requirement - (clock arrival + clock path + data path + uncertainty))    Source:                dout_2  (FF)    Destination:           dout<2>  (PAD)    Source Clock:         clk_out_OBUF_BUFG rising at 0.000ns    Requirement:          5.000ns    Data Path Delay:      3.731ns (Levels of Logic = 1)    Clock Path Delay:     4.523ns (Levels of Logic = 2)    Clock Uncertainty:    0.025ns
   Clock Uncertainty:          0.025ns  ((TSJ^2 + TIJ^2)^1/2 + DJ) / 2 + PE      Total System Jitter (TSJ):  0.050ns      Total Input Jitter (TIJ):   0.000ns      Discrete Jitter (DJ):       0.000ns      Phase Error (PE):           0.000ns
Maximum Clock Path at Slow Process Corner: clk_in to dout_2
     Location             Delay type         Delay(ns)  Physical Resource                                                         Logical Resource(s)      -------------------------------------------------  -------------------      W12.I                 Tiopi                  1.037   clk_in
clk_in
IBUFG_u0
ProtoComp0.IMUX.14
     BUFGMUX_X2Y9.I0      net (fanout=2)        0.987    clk_out_OBUF
     BUFGMUX_X2Y9.O        Tgi0o                  0.209   clk_out_OBUF_BUFG
clk_out_OBUF_BUFG
     OLOGIC_X27Y31.CLK0   net (fanout=96)       2.290    clk_out_OBUF_BUFG
     -------------------------------------------------  ---------------------------      Total                                      4.523ns (1.246ns logic, 3.277ns route)                                                         (27.5% logic, 72.5% route)
Maximum Data Path at Slow Process Corner: dout_2 to dout<2>
     Location             Delay type         Delay(ns)  Physical Resource                                                         Logical Resource(s)      -------------------------------------------------  -------------------      OLOGIC_X27Y31.OQ      Tockq                  1.080   dout_2
dout_2
     W20.O                net (fanout=1)        0.309    dout_2
     W20.PAD               Tioop                  2.342   dout<2>
dout_2_OBUF
dout<2>
     -------------------------------------------------  ---------------------------      Total                                      3.731ns (3.422ns logic, 0.309ns route)                                                         (91.7% logic, 8.3% route)
Fastest Paths: TIMEGRP "dout" OFFSET = OUT 5 ns AFTER COMP "clk_in" REFERENCE_PIN BEL          "clk_out" TIMEGRP dout_r "RISING";  --------------------------------------------------------------------------------
Paths for end point dout<1> (U22.PAD), 1 path  --------------------------------------------------------------------------------  Delay (fastest paths):   3.003 ns (clock arrival + clock path + data path - uncertainty)    Source:                dout_1  (FF)    Destination:           dout<1>  (PAD)    Source Clock:         clk_out_OBUF_BUFG rising at 0.000ns    Data Path Delay:      1.564ns (Levels of Logic = 1)    Clock Path Delay:     1.464ns (Levels of Logic = 2)    Clock Uncertainty:    0.025ns
Minimum Clock Path at Fast Process Corner: clk_in to dout_1
     Location             Delay type         Delay(ns)  Physical Resource                                                         Logical Resource(s)      -------------------------------------------------  -------------------      W12.I                 Tiopi                  0.321   clk_in
clk_in
IBUFG_u0
ProtoComp0.IMUX.14
     BUFGMUX_X2Y9.I0      net (fanout=2)        0.265    clk_out_OBUF
     BUFGMUX_X2Y9.O        Tgi0o                  0.059   clk_out_OBUF_BUFG
clk_out_OBUF_BUFG
     OLOGIC_X27Y40.CLK0   net (fanout=96)       0.819    clk_out_OBUF_BUFG
     -------------------------------------------------  ---------------------------      Total                                      1.464ns (0.380ns logic, 1.084ns route)                                                         (26.0% logic, 74.0% route)
Minimum Data Path at Fast Process Corner: dout_1 to dout<1>
     Location             Delay type         Delay(ns)  Physical Resource                                                         Logical Resource(s)      -------------------------------------------------  -------------------      OLOGIC_X27Y40.OQ      Tockq                  0.336   dout_1
dout_1
     U22.O                net (fanout=1)        0.190    dout_1
     U22.PAD               Tioop                  1.038   dout<1>
dout_1_OBUF
dout<1>
     -------------------------------------------------  ---------------------------      Total                                      1.564ns (1.374ns logic, 0.190ns route)                                                         (87.9% logic, 12.1% route)
就不明白为什么dout【1】和dout【2】的结果差异这么大?如何可以让这一组数据约束出来结果差不多呢?
GMT+8, 2025-12-26 11:00 , Processed in 0.013459 second(s), 5 queries , Gzip On, Redis On.
