查看: 2718|回复: 0
[求助] 问:CLK signal frequency error和required accuracy的区别
发表于 2016-5-9 09:31:03 | 显示全部楼层 |阅读模式
在UTMI的spec在中有这样几句话让我醉了:
2) The CLK signal frequency error must be less than 10% (±6.00 MHz)
3) The CLK must fully meet the required accuracy of ±500 ppm (±30.0 KHz), no later than 1.4ms after the
first transition of CLK.
请问这两点分别是啥?咋看上去像是一个东西呢,但是数值又不一样
GMT+8, 2025-12-3 21:11 , Processed in 0.016851 second(s), 5 queries , Gzip On, Redis On.
