查看: 1847|回复: 1
[求助] Functional Coverage without SystemVerilog
发表于 2012-12-15 08:05:53 | 显示全部楼层 |阅读模式
Functional Coverage Without SystemVerilog
How to collect functional coverage information using VHDL or SystemC
Here you can download the following paper:
    Event: DVCon 2010, San Jose, February 2010
    Title: "Functional Coverage Without SystemVerilog"
    Author: Alan Fitch and Doug Smith, Doulos
Abstract
In recent years the use of functional coverage has become the dominant method for managing the verification process for large SoC developments. However this has been mainly in the ASIC arena, using SystemVerilog-based methodologies such as OVM and VMM. Of course there are also large SoCs being designed using Field Programmable Gate Arrays (FPGAs) - in fact there is a concentration of advanced FPGA users on the US East Coast, in the military/aerospace sector: and many of them are using VHDL. This then raises the question of how to use functional coverage in the older yet still popular HDLs; is it possible to implement functional coverage in a usable and efficient way without using SystemVerilog?
We will start with a short overview of functional coverage and its application.
The main body of the paper uses VHDL as an example, and shows how functional coverage may be collected. Firstly we look at an example of how either PSL or SVA coverpoints may be bound to VHDL code, and coverage data stored in proprietary format (a technique which is also applicable to both Verilog and SystemC).
Then we investigate how to write functional coverage information using concurrent procedure calls together with VHDL attributes. We will show the VHDL language features for data assignment monitoring and introspection which allow a file of coverage information to be stored. We will show how to post-process data in the text file for injection into a proprietary database format; and also how to make sure that the cover points do not affect synthesis when embedded in RTL code.
 楼主| 发表于 2012-12-15 16:22:47 | 显示全部楼层
Sorry! It''s double posted because of network problem. The pdf is available here:
http://bbs.eetop.cn/thread-366310-1-2.html
GMT+8, 2025-11-5 08:29 , Processed in 0.015034 second(s), 6 queries , Gzip On, Redis On.
