查看: 5987|回复: 4
[求助] 状态机的问题
发表于 2012-11-21 11:58:34 | 显示全部楼层 |阅读模式
我自己写的一个自动售货机的代码,但是quartus ii提示:
Warning (10199): Verilog HDL Case Statement warning at sellor.v(77): case item expression never matches the case expression,从s20开始的状态都没有出现,请问是怎么回事啊?不知道为什么不会出现s20及其以后的状态,求大神指点!
module sellor (
                clk,coin_valid,din5,din10,din15,din20,din25,rst_n,
coin_accept,coin_enough,candy_out,dout
input wire clk;
input wire coin_valid,din5,din10,din15,din20,din25;
input wire rst_n;
output reg coin_accept,candy_out;
output reg [3:0]dout;
output reg coin_enough;
parameter s0 = 0000, s5 = 0001, s10 = 0011, s15 = 0010, s20 = 0110,
          s25 = 0111,s30 = 0101, s35 = 0100, s40 = 1100,s45 = 1101;
reg [3:0]state;
always @(posedge clk or negedge rst_n)
if (!rst_n)
   begin
    state <= s0;
coin_enough <= 0;
coin_accept <= 0;
end
/*decide the state of the finite state machine*/
else if (coin_valid)
  begin
    case (state)
   s0:
   if (din5)//is it the priority decoder?? maybe using case is different;
state <= s5;
else if (din10)
  state <= s10;
else if (din15)
  state <= s15;
else if (din20)
  state <= s20;
else if (din25)
  state <= s25;
else
  state <= s0;
s5:
   if (din5)
  state <= s10;
else if (din10)
  state <= s15;
else if (din15)
  state <= s20;
else if (din20)
  state <= s25;
else if (din25)
  state <= s30;
else
  state <= s5;
s10:
   if (din5)
  state <= s15;
else if (din10)
  state <= s20;
else if (din15)
  state <= s25;
else if (din20)
  state <= s30;
else if (din25)
  state <= s35;
else
  state <= s10;
s15:
   if (din5)
  state <= s20;
else if (din10)
  state <= s25;
else if (din15)
  state <= s30;
else if (din20)
  state <= s35;
else if (din25)
  state <= s40;
else
  state <= s15;
s20:
   if (din5)
  state <= s25;
else if (din10)
  state <= s30;
else if (din15)
  state <= s35;
else if (din20)
  state <= s40;
else if (din25)
  state <= s45;
else
  state <= s20;
default:
   begin
     state <= state;// can i express like this ??
  coin_enough <= 1;
         end
endcase
coin_accept <= 1;
end
else
   state <= state;//the state of the fsm keep unchanged;
/*deal with the output candy_out of the machine*/
always @(state or rst_n) // is it neccessary to use a if sentence?
  if (!rst_n)
    begin
     candy_out = 0;
  dout = 4'b0000;
end
else
   case (state)
s25:
     begin
    candy_out = 1;
dout = 4'b00_00;
state = s0;
  end
s30:
  begin
    candy_out = 1;
    dout = 4'b00_01;
state = s0;
end
   s35:
  begin
    candy_out = 1;
dout = 4'b00_10;
state = s0;
  end
s40:
  begin
    candy_out = 1;
dout = 4'b01_00;
state = s0;
     end
s45:
  begin
    candy_out = 1;
dout = 4'b10_00;
state = s0;
  end
default:
  begin
    candy_out = 0;
dout = 4'b00_00;
state = state;
  end
   endcase
endmodule
发表于 2012-11-21 16:21:33 | 显示全部楼层
学习一下
 楼主| 发表于 2012-11-21 16:40:41 | 显示全部楼层
谢谢各位,我找到问题了,parameter应该是s0=4’b0000;自己太粗心了!!
发表于 2012-11-21 17:59:08 | 显示全部楼层
这代码风格跟谁学的?不出错都难,出错也难debug。。。
 楼主| 发表于 2012-11-21 21:54:05 | 显示全部楼层
回复 4# elec_zxm
    可不可以给点指导啊?自己看的书~~夏宇闻的那本书~~
GMT+8, 2025-12-6 01:34 , Processed in 0.017744 second(s), 6 queries , Gzip On, Redis On.
