查看: 7318|回复: 10
[求助] icc中修复min_capacitance的violation
发表于 2012-11-20 22:17:12 | 显示全部楼层 |阅读模式
各位大神:在icc中如何去修复min_capacitance的violation呢?这种min_capacitance的violation是怎么造成的呢?修复的原理是什么呢?
小妹在此谢过了!
发表于 2012-11-20 22:47:22 | 显示全部楼层
DESCRIPTION
Sets the min_capacitance attribute to capacitance_value on the specified input ports. compile attempts to ensure that the load driven by the input port is not reduced below capacitance_value. The minimum capacitance value for a net is defined as the greatest of the minimum capacitance values of the driving cell pins and ports on a net.
If min_capacitance attributes are already specified in a technology library (implicit constraints), compile automatically tries to meet them.
By default, a port has no min_capacitance constraint.
min_capacitance, along with max_fanout and max_transition, is a design rule constraint; max_delay and max_area are optimization constraints. Design rule constraints reflect those technology-specific restrictions that must be met for a design to function correctly, while optimization constraints reflect goals and restrictions that are desirable, but not crucial for the operation of a design. Design Compiler attempts to meet all constraints placed on a design, but gives priority to design rule constraints in the optimization process. Therefore, compile gives preference to min_capacitance and other design rule constraints, even if they adversely affect optimization constraints on a design.
To get information about optimization and design rule constraints, use report_constraint; to get information on the current port settings, use report_port. To remove the min_capacitance attribute from a port, use remove_attribute.
发表于 2012-11-20 22:47:57 | 显示全部楼层
drc的约束?
发表于 2012-11-20 22:51:09 | 显示全部楼层
回复 1# wy27510
    修复原理就是用一个大input load的cell接上去吗?
看其说明,应该是个input port,port是接pad的话,怎么去优化这个呢?
待大牛现身解答~
 楼主| 发表于 2012-11-21 09:08:21 | 显示全部楼层
    如果修改了drc约束的话,在route的时候会不会出问题呢?您指的修改drc约束是指修改布线时线宽或者线与线之间的间距以修复min_cap的目的吗?
 楼主| 发表于 2012-11-21 09:10:43 | 显示全部楼层
回复  wy27510
看其说明,应该是个input port ...
sjtusonic 发表于 2012-11-20 22:51
    那我可否加一个buffer上去,增加它的load,这样做是否可行呢?
发表于 2012-11-21 13:56:55 | 显示全部楼层
我一般遇到的是max_capacitance和max_transition的violated,但都不考虑。我也不知道怎么回事,希望知道的可以指点一二。在此谢过了!
 楼主| 发表于 2012-11-21 15:40:47 | 显示全部楼层
回复 7# Alicezw
    我在一些资料上看到max_transition如果是pad上的话貌似是可以不管的,但是内部的话好像就得修,添加buffer不知是否好使
发表于 2012-11-21 19:39:03 | 显示全部楼层
回复 11# wy27510
    哦,嗯,谢谢!
    可能我还是需要再看看基本的资料,因为对这些概念还不是很清楚。
发表于 2012-11-27 19:22:15 | 显示全部楼层
前几天我也遇到了这个  当时是在有min_capacitance violation的地方插buffer修好的  你试试看行不行
GMT+8, 2025-12-30 14:18 , Processed in 0.652946 second(s), 5 queries , Gzip On, Redis On.
