查看: 2495|回复: 3
[求助] 关于IES的问题请教,谢谢
发表于 2012-10-11 21:40:11 | 显示全部楼层 |阅读模式
when i use IES to post-simulation,i meet with the problem as below:
ncelab : *W,FLFEXS: Expected string but found name "abc_top_max.sdf.X" in SDF annotation command file  /a/b/c/sdf.cmd, line 1,trying to continue.
ncealb: *W,FLFFNF:Compiled SDF file (abc_top_max.sdf.X) not found,specified in SDF annotation command file /a/b/c/sdf.cmd, line 3.
so.the annotation is failed.
Surely,I check my sdf.cmd,the format is the same as the cdnshelp description.
thanks.
发表于 2012-10-13 13:44:58 | 显示全部楼层
回复 1# sunjianty
me too
发表于 2012-10-13 15:14:21 | 显示全部楼层
check PATH and some variables in ENV
 楼主| 发表于 2012-10-13 21:11:08 | 显示全部楼层
回复 3# 飞扬紫百合
    环境都是好的,tb使用VHDL写的,之前测试也是好的。。。但是软件licence很有限,其他的licence是盗版的,在想是不是和盗版软件有关。。。
而且在当TB用verilog写,且用$annotate函数的时候,结果是好的。。。
GMT+8, 2025-12-22 10:14 , Processed in 0.020895 second(s), 7 queries , Gzip On, Redis On.
