楼主: scuay
[资料] 我的文档(后端设计相关文档、资料、工具等内容)
发表于 2012-9-13 10:15:27 | 显示全部楼层
膜拜之中啊。。。。。。。。。。。。。。。
 楼主| 发表于 2012-9-14 12:08:23 | 显示全部楼层
几篇OSC论文:
2006 A Paper from VTI A 3 spl muW, 2 MHz CMOS frequency reference for capacitive sensor applications.pdf
2007 Low Voltage Low Power CMOS Oscillator with Low Temperature and Process Sensitivity.pdf
2010 Analysis and Design of an Ultralow-power CMOS Relaxation Oscillator.pdf
2012 A 32.4 ppm°C 3.2-1.6V self-chopped relaxation oscillator with adaptive supply generation.pdf
A new compact temperature-compensated CMOS current reference.pdf
Analysis and Design of an Ultralow-Power CMOS Relaxation Oscillator.pdf
Process and temperature compensation in a 7-MHz CMOS clock oscillator.pdf
Process-Invariant Current Source Design - Methodology and Examples.pdf
Temperature compensated IBAR reference oscillators.pdf
Temperature insensitive current reference for the 6.27 MHz oscillator.pdf
OSC.zip (6.65 MB , 下载次数: 164 )
 楼主| 发表于 2012-9-14 12:48:47 | 显示全部楼层
一些有关加速度计的资料:
A 1.5uW 1V 2nd-order ΔΣ sensor front-end with signal boosting and offset compensation for a capacitive 3-axis micro-accelerometer.pdf
A 21.2uA SD-based interface ASIC for a capacitive 3-axis micro-accelerometer.pdf
A 3 μW,2 MHz CMOS frequency reference for capacitive sensor applications.pdf
A 60-dB Dynamic-Range CMOS Sixth-Order 2.4-Hz Low-Pass Filter for Medical Applications.pdf
A 62uA interface ASIC for a capacitive 3-axis micro-accelerometer.pdf
A CMOS Z-Axis Capacitive Accelerometer With Comb-Finger Sensing.pdf
A CMOS-compatible high aspect ratio silicon-on-glass in-plane micro-accelerometer.pdf
A HIGH RESOLUTION, STICTIONLESS, CMOS COMPATIBLE SOI ACCELEROMETER WITH A LOW NOISE, LOW POWER, 0.25μM CMOS INTERFACE.pdf
A High Temperature Precision Amplifier.pdf
A High-Performance MEMS Capacitive Strain Sensing System.pdf
A HYBRID SILICON-ON-GLASS (SOG) LATERAL MICRO-ACCELEROMETER WITH CMOS READOUT CIRCUITRY.pdf
A large-displacement CMOS micromachined thermal actuator with comb electrodes for capacitive sensing.pdf
A Large-Scale Reconfigurable Smart Sensory Chip.pdf
A LATERAL CAPACITIVE CMOS ACCELEROMETER WITH STRUCTURAL CURL COMPENSATION.pdf
A Low-Noise Low-Offset Capacitive Sensing Amplifier for a 50ugHz Monolithic CMOS MEMS Accelerometer.pdf
A Low-Power Switched-Capacitor Capacitive Transducer with High Resolution.pdf
A micropower front end for three-axis capacitive microaccelerometers.pdf
A micropower interface ASIC for a capacitive 3-axis micro-accelerometer.pdf
A Micropower Sigma Delta Based Interface ASIC for a Capacitive 3-Axis Micro-Accelerometer.pdf
A micropower voltage, current, and temperature reference for a low power capacitive sensor interface.pdf
A Mixed-Voltage Sensor Readout Circuit With On-Chip Calibration and Built-In Self-Test.pdf
A modular process for integrating thick polysilicon MEMS devices with sub-micron CMOS.pdf
A Monolithic Surface Micromachined Z-Axis Gyroscope with Digital Output.pdf
A Monolithic Surface MicromachinedAccelerometer with Digital Output.pdf
A Post-CMOS Micromachined Lateral Accelerometer.pdf
A Resonant Accelerometer With Two-Stage Mciroleverage Mechanisms Fabricated by SOI-MEMS Technology.pdf
A sensitive electronic capacitance measurement system to measure comb drive motion of surface micromachined MEMS devices.pdf
a single mask, single-crystal silicon, reactive ion etching process for micro electro mechanical structures.pdf
A Three-Axis Micromachined Accelerometer with a CMOS Position-Sense Interface and Digital Offset-Trim Electronics.pdf
Amicromachined 2D positioner with electrothermal actuation and sub-nanometer capacitive sensing.pdf
An Inertial Sensor Technology Using DRIE and Wafer Bonding with Interconnecting Capability.pdf
An integrated digital silicon micro-accelerometer with MOSFET-type sensing elements.pdf
An Integrated Low-Voltage Class AB CMOS OTA.pdf
An Integrated Resonant Accelerometer Microsystem for Automotive Applications.pdf
An Offset-Canceling Low-Noise Lock-In Architecture for Capacitive Sensing.pdf
Application of MEMS Technology in Automotive Sensors and Actuators.pdf
CAPACITIVE CMOS READOUT CIRCUITS FOR HIGH PERFORMANCE MEMS ACCELEROMETERS.pdf
Capacitive detection in resonant MEMS with arbitrary amplitude of motion.pdf
CHARGE-BASED ANALOG CIRCUITS FOR RECONFIGURABLE SMART SENSORY SYSTEMS(PHD).pdf
CMOS 3-AXIS ACCELEROMETERS WITH INTEGRATED AMPLIFIER.pdf
CMOS MEMS – PRESENT AND FUTURE.pdf
Comparison of Multisensor Fusion Techniques for Improvement of Measurement Accuracy with MEM Accelerometers.pdf
Design and characterization of an air-coupled capacitive ultrasonic sensor fabricated in a CMOS process.pdf
Design and Implementation of a Tunable 40 MHz-70 MHz Gm-C Bandpass Sigma-Delta Modulator.pdf
Design, Fabrication, and Measurementof High-Sensitivity Piezoelectric Microelectromechanical Systems Accelerometers.pdf
Development of Drie CMOS MEMS Process and Integrated Acceletrometers2006.pdf
Embedded Micromechanical Devices for the Monolithic Integration of MEMS with CMOS.pdf
errata_of_articles_P4_P6.pdf
Features and Design Constraints for an OptimizedSC Front-End Circuit for Capacitive Sensors With a Wide Dynamic Range-heidary2008.pdf
Fully integrated signal conditioning of an accelerometer for implantable pacemakers.pdf
High Frequency CMOS Switched-Capacitor Filters For Communications application.pdf
INTEGRATED INTERFACE ELECTRONICS FOR CAPACITIVE MEMS INERTIAL SENSORS.pdf
Integrated Micro-Electro-Mechanical Sensor Development for Inertial Applications.pdf
INTEGRATED REFERENCE CIRCUITS FOR LOW-POWER CAPACITIVE SENSOR INTERFACES.pdf
Jitter analysis of high-speed sampling systems.pdf
Lectures on MEMS and MICROSYSTEMS DESIGN AND MANUFACTURE Chapter 1.pdf
Low-Noise CMOS Integrated Sensing Electronics for Capacitive MEMS Strain Sensors.pdf
LOW-POWER FRONT-ENDS FOR CAPACITIVE THREE-AXIS ACCELEROMETERS.pdf
Mechanical Noise-Limited CMOS-MEMS Accelerometers.pdf
MEMS Manufacturing Testing An Accelerometer Case Study.pdf
MEMS-based optical mini- and microspectrometers for the visible and infrared spectral range.pdf
MEMS传感器弱信号检测电路及集成设计.pdf
MEMS电容传感器信号处理ASIC研究与设计.pdf
MEMS电容式微加速度计检测电路研究.pdf
MICRO-ELECTRO-MECHANICAL SYSTEMS(MEMS) AND FLUID FLOWS.pdf
Micro-gravity capacitive silicon-on-insulator accelerometers.pdf
Micromachined Structures Fabricated Using A Wafer-Bonded Sealed Cavity Process.pdf
Noise Analysis and Characterization of a Sigma-Delta Capacitive Microaccelerometer.pdf
PARALLEL PLATE CAPACITIVE DETECTION OF LARGE AMPLITUDE MOTION IN MEMS.pdf
Polymer Based Wafer Level Packaging of Micromachined HARPSS Devices 2006.pdf
Prototype Feedback-Controlled Bidirectional Actuation System for MEMS Applications.pdf
SINGLE MASK LATERAL TUNNELING ACCELEROMETER.pdf
STRUCTURED DESIGN OF INTEGRATED MEMS.pdf
Surface Micromachined Accelerometers.pdf
Temperature stablization of CMOS capacitive accelerometers.pdf
Three-axis SOI capacitive accelerometer with PLL C–V converter.pdf
一种用于电容型体硅微陀螺的低噪声读出电路芯片.pdf
加速度计资料.part1.rar (15 MB , 下载次数: 103 )
加速度计资料.part2.rar (15 MB , 下载次数: 93 )
加速度计资料.part3.rar (15 MB , 下载次数: 93 )
加速度计资料.part4.rar (15 MB , 下载次数: 94 )
加速度计资料.part5.rar (15 MB , 下载次数: 95 )
加速度计资料.part6.rar (15 MB , 下载次数: 93 )
加速度计资料.part7.rar (7.13 MB , 下载次数: 69 )
 楼主| 发表于 2012-9-14 14:03:24 | 显示全部楼层
【JSSC系列论文】
2007年1月份:
JSSC_2007_01.part1.rar (15 MB , 下载次数: 22 )
JSSC_2007_01.part2.rar (15 MB , 下载次数: 21 )
JSSC_2007_01.part3.rar (15 MB , 下载次数: 14 )
JSSC_2007_01.part4.rar (15 MB , 下载次数: 20 )
JSSC_2007_01.part5.rar (595.99 KB , 下载次数: 9 )
 楼主| 发表于 2012-9-14 14:16:31 | 显示全部楼层
【JSSC系列论文】
2007年2月份:
JSSC_2007_02.part1.rar (15 MB , 下载次数: 21 )
JSSC_2007_02.part2.rar (15 MB , 下载次数: 20 )
JSSC_2007_02.part3.rar (3.8 MB , 下载次数: 19 )
 楼主| 发表于 2012-9-14 14:30:55 | 显示全部楼层
【JSSC系列论文】
2007年3月份:
JSSC_2007_03.part1.rar (15 MB , 下载次数: 16 )
JSSC_2007_03.part2.rar (15 MB , 下载次数: 18 )
JSSC_2007_03.part3.rar (6.44 MB , 下载次数: 17 )
 楼主| 发表于 2012-9-14 14:45:13 | 显示全部楼层
【JSSC系列论文】
2007年4月份:
JSSC_2007_04.part1.rar (15 MB , 下载次数: 24 )
JSSC_2007_04.part2.rar (15 MB , 下载次数: 21 )
JSSC_2007_04.part3.rar (15 MB , 下载次数: 19 )
JSSC_2007_04.part4.rar (2.96 MB , 下载次数: 20 )
发表于 2012-9-17 03:54:00 | 显示全部楼层
太感谢了,都是有用的资料
 楼主| 发表于 2012-9-17 10:33:26 | 显示全部楼层
【JSSC系列】
2007年5月份:
JSSC_2007_05.part1.rar (15 MB , 下载次数: 23 )
JSSC_2007_05.part2.rar (15 MB , 下载次数: 18 )
JSSC_2007_05.part3.rar (11.83 MB , 下载次数: 20 )
 楼主| 发表于 2012-9-17 13:21:49 | 显示全部楼层
【JSSC系列】
2007年
6月份
JSSC_2007_06.part1.rar (15 MB , 下载次数: 19 )
JSSC_2007_06.part2.rar (15 MB , 下载次数: 19 )
JSSC_2007_06.part3.rar (10.85 MB , 下载次数: 23 )
7月份
JSSC_2007_07.part1.rar (15 MB , 下载次数: 14 )
JSSC_2007_07.part2.rar (15 MB , 下载次数: 20 )
JSSC_2007_07.part3.rar (5.2 MB , 下载次数: 19 )
8月份
JSSC_2007_08.part1.rar (15 MB , 下载次数: 19 )
JSSC_2007_08.part2.rar (15 MB , 下载次数: 13 )
JSSC_2007_08.part3.rar (3.89 MB , 下载次数: 21 )
9月份
JSSC_2007_09.part1.rar (15 MB , 下载次数: 22 )
JSSC_2007_09.part2.rar (15 MB , 下载次数: 21 )
JSSC_2007_09.part3.rar (9.53 MB , 下载次数: 19 )
10月份
JSSC_2007_10.part1.rar (15 MB , 下载次数: 17 )
JSSC_2007_10.part2.rar (15 MB , 下载次数: 21 )
JSSC_2007_10.part3.rar (15 MB , 下载次数: 19 )
JSSC_2007_10.part4.rar (391.29 KB , 下载次数: 8 )
11月份
JSSC_2007_11.part1.rar (15 MB , 下载次数: 13 )
JSSC_2007_11.part2.rar (15 MB , 下载次数: 18 )
JSSC_2007_11.part3.rar (15 MB , 下载次数: 17 )
JSSC_2007_11.part4.rar (3.26 MB , 下载次数: 19 )
12月份
JSSC_2007_12.part1.rar (15 MB , 下载次数: 19 )
JSSC_2007_12.part2.rar (15 MB , 下载次数: 20 )
JSSC_2007_12.part3.rar (15 MB , 下载次数: 19 )
JSSC_2007_12.part4.rar (15 MB , 下载次数: 19 )
JSSC_2007_12.part5.rar (15 MB , 下载次数: 19 )
JSSC_2007_12.part6.rar (1.53 MB , 下载次数: 18 )
15 MB, 下载次数: 1 , 下载积分: 资产 -5 信元, 下载支出 5 信元
1.53 MB, 下载次数: 1 , 下载积分: 资产 -2 信元, 下载支出 2 信元
11.83 MB, 下载次数: 1 , 下载积分: 资产 -4 信元, 下载支出 4 信元
10.85 MB, 下载次数: 1 , 下载积分: 资产 -4 信元, 下载支出 4 信元
5.2 MB, 下载次数: 1 , 下载积分: 资产 -3 信元, 下载支出 3 信元
3.89 MB, 下载次数: 1 , 下载积分: 资产 -2 信元, 下载支出 2 信元
9.53 MB, 下载次数: 1 , 下载积分: 资产 -4 信元, 下载支出 4 信元
391.29 KB, 下载次数: 1 , 下载积分: 资产 -2 信元, 下载支出 2 信元
3.26 MB, 下载次数: 1 , 下载积分: 资产 -2 信元, 下载支出 2 信元
GMT+8, 2025-12-31 00:39 , Processed in 0.025149 second(s), 5 queries , Gzip On, Redis On.
